![]() | Home > Puma (Tdci) > Inexpensive puma gear knob solution? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17675 ![]() ![]() ![]() |
It's not a pool ball, it's a classic gear lever knob!
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
jajajaja
![]() ![]() ![]() I`m in the same boat now, the gear knob starting to fell apart after several years with cracks. Probably I will take the Jeepy approach using the 12mm insert to put a new knob ¿Someone have pictures of the insert? Cheers! Edit: I found it... ![]() Click image to enlarge Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Jeepy Member Since: 30 Apr 2018 Location: Aquitaine Posts: 4 ![]() ![]() ![]() |
Do it Eduardo!
Thanks Jeepy
How do you fix the knob to the rod? My first attempt of Knob using the 3D printer looks Ok in the shape but a little small. I will repeat the print but bigger. Cheers! ![]() Click image to enlarge ![]() Click image to enlarge Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2220 ![]() ![]() |
In English a "Rampa-Muffe" would equate to a “Self tapping threaded insert” , but I much prefer the sound of a "Rampa-Muffe"
Just 2 screws for stop rotation ,simple is best ![]() ![]() Click image to enlarge |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
Nice, ideally you hit one of the existing recesses? Note, the headlight adjustment is activated
Thanks to all!!!!
Im now in the process to print the 2nd attempt. Hope I got the right size now. Cheers from Chile Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
First attempt!
![]() Click image to enlarge Next one will be longer to hide the rod and with an insert to attach the screw, but in general terms looks OK. (take out the plastic is difficult but doable). Cheers to all Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
2nd attempt
![]() Click image to enlarge Looks OK now. Thanks to all for the ideas! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Klein Kameel Member Since: 29 May 2018 Location: Pretoria Posts: 2 ![]() ![]() |
Hi Eduardo
Are you willing to share your file or perhaps sell it to me as I'm in the same situation with my gear knob. A friend of mine have got a 3D printer and he can do the printing for me. Regards Andre |
No problem Klein!
Give me an email and I sent you the file Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Thanks Eduardo
It is andre@celsusimago.co.za Regards |
