Home > Puma (Tdci) > Inexpensive puma gear knob solution?
Page 1 of 5 12345>
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Hi. As in the picture my Puma gear knob has been perished/ cracked probably due to excessive heaty climate these days and as a temporary solution I have glued together but doubt how long it lasts.
I noted that to change just the damn gear knob you have to change the whole gear leaver as a kit which I found very costly. I'm sure it will perish again even I replaced. Has anyone got an inexpensive simple solution just to replace this crappy knob.?
Post #521552 6th Apr 2016 4:15pm
dorsetsmith
Find away to making your own or find out who make then for fords, find aluminium puma gear knob but its £ 380 not inexpensive
Post #521554 6th Apr 2016 4:25pm
Swac3
There was a thread somewhere about cutting it off to expose the shaft inside, its not threaded tho apparently so you'd end up either gluing one on or cutting your own thread into the rod, possibly not the most elegant solution but likely the cheapest.
Found it its on AULRO. 3 Landrovers
Post #521573 6th Apr 2016 5:27pm
any link?
Post #521690 6th Apr 2016 9:21pm
Likeomg
how much is the kit?
i have one lying around that i could part with...
Post #521696 6th Apr 2016 9:25pm
RED-DOT
Wrap it with Baco foil and put a red & yellow ring at the base and your life will be at one with the Spirit world. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #521701 6th Apr 2016 9:33pm
jimbob7
/\/\/\what she said,lol. Pov.spec,ftw. 2006, 110,TD5.
Post #521831 7th Apr 2016 10:40am
K9F
You've just burst my bubble. A Scotsman with a great sense of humour. Great post Alex, thank you. Rolling with laughter Bow down Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #521860 7th Apr 2016 1:02pm
AlexSmith
Brazil 2004 Defender 110 300 Tdi SW Alpine White
They say this end is compatible with the Defender, but I'm not sure how it would fit... Worth a try for the price though...
http://www.ebay.co.uk/itm/380839995311
 2020: Defender 110 SW 300 Tdi 2004 Alpine White
2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray
2002-2005: Defender 90 CSW 300 Tdi Dark Green
Post #553793 4th Aug 2016 11:07pm
dorsetsmith
Post #553817 5th Aug 2016 7:33am
ashtrans
Site Sponsor
Hi,
I have loads of these brand new from auto conversions, £25 each + carriage
I am now off for a week but if you want one email me a week on Monday
Dave Dave
Post #554004 6th Aug 2016 8:06am
BADCADI
Switzerland 2010 Defender 110 Puma 2.4 CSW Alaska White
Resurrecting an old thread:
Does anyone still have some replacement gear lever/knobs, or found a good solution to the gear know disintegrating issue?
Thanks.
BADCADI
Post #889417 6th Mar 2021 1:32pm
Post #889433 6th Mar 2021 2:42pm
BADCADI
Thanks blackwolf ..... not ready for that 'drastic' solution just yet, but will certainly keep in in mind. Whistle
Post #889471 6th Mar 2021 6:10pm
Samblers
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
I just fixed mine using a kneadable 2-part black-coloured epoxy called PC-7 (from USA)
It was cracked all over and a chunk had fallen off. I glued the chunk back on and filled up the cracks, wiped off the excess. Actually looks quite OK now and the epoxy dries hard, meaning it feels fine too
Post #891251 14th Mar 2021 12:53am
Page 1 of 5 12345>
