Home > Puma (Tdci) > New Airbox from Alisport
Page 1 of 7 1234567>
Bluest
Looks good, similar concept to the Nugget one, but with the correct mounting arrangement for the cartridge which should avoid the problem of finding replacement filters.
https://m.facebook.com/story.php?story_fbi...sn=scwspmo 2007 110 TDCi Station Wagon XS
Post #1007055 9th Sep 2023 10:14pm
Devon-Rover
It does look nice in the engine bay and the removal of the factory air ducting can only be a good thing.
It's the £500 price tag that scares me, Shocked Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1011013 12th Oct 2023 4:53pm
Worse than that, it is £507 plus VAT ! Very nice though.
I'm intrigued to see that the "low intake" version is vastly cheaper at a mere £283 plus VAT, but I am guessing that it may not come with the wing intake and pipe on the theory that you will use the OEM pipework. However it is probably ideal if you already have a Nuggetstuff or Nakatanega induction pipe set-up.
I might ne day be tempted to replace my Nuggetstuff filter with this one!
Post #1011022 12th Oct 2023 7:03pm
Ianh
Great video...interesting to see the graphs on the benefits of improved intake airflow. I have experienced the same with the nakatanenga intake pipe coupled to the nuggetstuff v2 airbox.
Somewhat underplays the ease of getting the old airbox out, noting looks like the siide bracket is broke which makes it a bit easier. Very Happy
Did not mention any water drain facility, so assume it does not have one
Bluest,
I’m sure you could mod the nugget stuff v2 box to have a sealed bolt (using rubber seals flat washers and a nut) going through the top of the airbox , through the filter, then a rubber seal, large washer and then nut to do an airtight clamp to the lid. Mimicking the alisport solution.
Post #1011023 12th Oct 2023 7:03pm
Bluest
Looks really well thought out. I like how it uses the original mountings too. 2007 110 TDCi Station Wagon XS
Post #1011024 12th Oct 2023 7:03pm
Ianh
It also looks a bigger filter than the nuggetstuff one.
Post #1011027 12th Oct 2023 7:09pm
geobloke
I keep lusting after the TD5 version of this air filter box. Looks amazing...
https://www.allisport.com/shop/performance...L9EALw_wcB
Post #1011030 12th Oct 2023 7:35pm
Bluest
Given some of the comments in the video I wonder if AliSport were discretely following the Nugget air filter saga thread on here 2007 110 TDCi Station Wagon XS
Post #1011031 12th Oct 2023 7:36pm
bankz5152
It is a really nice product, same as their TD5 ones, but it certainly will not add 38bhp.
Either that puma was HUGELY overfueling and needed that extra airflow or its just a barefaced lie.
You cannot add 38bhp with an airbox and no tuning, cant believe that video was posted in the first place.
For those that want a bigger air box and are fairly handy speak to Wrecker Fabrication, he makes very similar boxes for the TD5s just need a bit of fettling and work to fit, but a fraction of the cost. Instagram @defender_ventures
Empire Tuning - Agent
Post #1011033 12th Oct 2023 7:40pm
Ianh
I agree that it can’t be 38BHP...what I’ve noticed is a better more lively feel to the engine in all areas but nothing close to 30% more BHP
Post #1011038 12th Oct 2023 8:03pm
MartinK
Looks a really nice piece of kit! Some great comments above, too Smile I agree 38bhp sounds a tad ambitious Wink
I can see myself getting one! Good to see they have a replacement hose to the motor too... When's "black friday" Wink Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #1011066 13th Oct 2023 5:50am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Maybe 3.8bhp….? Whistle
Post #1011075 13th Oct 2023 8:00am
camelman
They specifically quote 8bhp for the TD5 version so expect 38 was a typo!
Post #1011094 13th Oct 2023 9:46am
Ianh
Re the power gain, he does say in the video “From the top of my head,at the top end of the Rev range it’s 38 horse power”, so it’s not just a typo, but he must have got that wrong.
I was also wondering how the lid sealed to the box, but then noticed it’s a seal on the top of the box. I would hope they will sell spare seals as at some point that might deteriorate or get inadvertently damaged.
Post #1011122 13th Oct 2023 12:20pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
He does make the statement that the 38bhp increase is at the top end of the rev range and if you look at the dyno graph in the video it does show that sort of bhp difference at around 4200 rpm. Obviously you're unlikely to drive around at that sort of revs, but there looks to be an increase over the whole rev range.
Post #1011125 13th Oct 2023 12:51pm
