Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1414 |
I remember when you launched it, I had a Disco 4 at the time and was using a Nanacom, I was a bit wary of spending all that money on a tool from a relatively unknown company but after using it for a couple of weeks I put the Nanacom up for sale and haven't looked back Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
28th Sep 2023 6:41pm |
I'll give you one guess where I got that information from Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
28th Sep 2023 6:45pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2752 |
They weren't particularly specific about what part was "incorrect" but it might have been the fact that they don't offer the power upgrade, or the above, or both.
lf anyone wants their services l would suggest just giving them a call. They seem to be a knowledgable outfit. |
29th Sep 2023 7:45am |
Defender_Virginia Member Since: 19 Sep 2023 Location: Virginia Posts: 10 |
Hi everyone - looking for some advice. I have a US-spec L663 110S that came with the basic LEDs. I bought a set of Premium LEDs on ebay and a GAP tool. Installed the new Premium LEDs and use the CCF to change
From: MultiCAN-679 HeadlightsVariant set to Headlamp_Variant_Low_C To: MultiCAN-679 HeadlightsVariant set to Headlamp_Variant_Mid_C I figured the Low=basic LEDs, Mid=Premium LEDs, and High=Matrix LEDs and then I kept it on C since I think that is USA. The headlights work fine but the DRLs are not working so wondering if there are other settings I need to be looking at? Thanks! |
30th Sep 2023 3:33pm |
My car is a UK model and has the Matrix headlamps and are set to
MultiCAN-679 HeadlightsVariant Headlamp_Variant_High_B As for the DRL's, you could check some of these settings MultiCAN-459 DRLVoltCtrl DRLs - voltage control- disabled MultiCAN-463 DRLBehWhilstDIsAct Dim MultiCAN-468 FntDRLType Incorporated DRL and Pos MultiCAN-470 DRLTransInteraction Stay ON in park or neutral MultiCAN-478 DRLFdbkMech BCM receives fault data via LIN MultiCAN-483 DRLDrvMech Driven via LIN MultiCAN-492 FntDRLProfile Diagnostic Profile 1 Again these are what mine are set at Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
30th Sep 2023 4:11pm |
Thanks Ian, I think I have all the same other than the variant. Do I need to look at EUCD-016 Dayrunning Light? It's currently set at Standard dipped light, (Non-DTRL).
30th Sep 2023 5:09pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 163 |
hi, thanks to Ian the drl settings are displayed, in theory your stock settings were supposed to make the drls work.
the correct setting is the one you write, mid=premium, c=usa. To help you I need some information, have you purchased used headlights complete with control units? are the headlights from the US market as a reference number? (we trust....but hopefully the drls are working). you can see the original chassis number of the headlight control units on ecu info, send mail button, save a complete description of all the ecu and see the chassis numbers referring to the headlights. with the chassis numbers you can understand if it is a US market car. Marco |
30th Sep 2023 5:12pm |
Thanks Marco - lights were in very good condition. I believe the control units are there. Headlights work and the side DRLs come on for a couple of seconds then go off. Haven't seen Main DRLs (half circles) come on yet. The car is a US market car - at least I think it is as I bought it new in the US. I bought the Headlights from a US vendor on Ebay shipped from US address to me so assume they are US spec also. Attached are photos of the stickers.
Click image to enlarge Click image to enlarge Click image to enlarge Last edited by Defender_Virginia on 30th Sep 2023 5:34pm. Edited 1 time in total |
30th Sep 2023 5:27pm |
I don't see the photo, you need to add it to the message, upload it to the system, and click on it.
insert a photo of the complete headlights. Marco |
30th Sep 2023 5:32pm |
Ok thanks - I think I got it that time. I edited the post....
30th Sep 2023 5:35pm |
I'm not sure, but looking around on the internet, it seems to me that FF is European market.....the lights of the American market, from what little I've seen, have different codes.
Marco Click image to enlarge |
30th Sep 2023 5:48pm |
thanks Marco - I tried the other country settings also for
MultiCAN-679 HeadlightsVariantHeadlamp_Variant_Med_(A, B & C) None of these setting made any difference to the main DRL. I just wonder if there are other CCF settings I need to be adjusting. I checked all the ones from Ian too. |
30th Sep 2023 6:08pm |
Mine is also set to EUCD-016 Dayrunning Light Standard dipped light. (Non-DTRL) Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
30th Sep 2023 6:13pm |
hi, there are no other settings for the premium headlights, for the European market it is medium-A.
your bcm, the gateways of your car are for the American market, so it probably doesn't work with an ecu setting for the European market, I have never retrofitted on US cars, I hope you find a solution, otherwise you will have to find two control units premium headlights from the American market. |
30th Sep 2023 6:15pm |
