Home > Maintenance & Modifications > Heavy duty or single piece half shafts?
Page 6 of 6 <123456
nicholas2012
Scotland 2010 Defender 90 Puma 2.4 HT Tamar Blue
Yes that's a good point mistakes are easy made, make plenty myself Laughing
Will message them on ebay and can hopefully exchange it for a HD shaft
Post #1007664 14th Sep 2023 11:59pm
MK
Does anyone measured the diameter of these 1 piece halfshafts? Puma 110" SW
Post #1007725 15th Sep 2023 4:23pm
nicholas2012
I think the diameter looks to be the same as the standard puma half shafts but removing the weakpoint of the outer splined drive flanges that always wear
Post #1007793 16th Sep 2023 9:22am
MK
Thumbs Up Puma 110" SW
Post #1007863 16th Sep 2023 5:13pm
Just been having a look at this thread as my DM’s could do with externally greasing again, I’ve got no problems with mine touch wood and running Ashcroft 2 piece rear.
Ashcroft HD flanges front, rest genuine front.
Blackwolf - Did you ever manage to get around to fitting a grease nipple to any HD DM caps?
I would like to do that, but the problem is with them currently fitted and the work involved it’s easier just to have some caps to swap over which isn’t cheap…
I wonder if the Terrafirma versions would fit and as it’s just caps I wonder if they would swap over, they are a lot cheaper.
Presumably the clearance is there in the centre of the alloy behind the centre cap and the DM cap with a grease nipple in the centre or would it need offsetting.
Would certainly be a lot faster and easier to grease, than having to take the caps off and also more effective.
I was thinking of using aerosol lithium into the splines as the pressure should help get it into the splines more effectively. WeWillWin🇬🇧🇺🇸
Post #1027540 10th Mar 2024 8:42pm
No, I went for single-piece halfshafts at the rear, the fronts are still Ashcroft HD with standard caps and seem to give no trouble.
Post #1027545 10th Mar 2024 8:59pm
I remember, that’s good. So I take it that you still just manually grease the front splines and all is okay. Thumbs Up
Though off topic, the A frame ball joint and bushes are also a common cause of a sloppy or loose rear often confused with rear driveshaft components. Mine was much better after the greasable A frame ball joint and A frame bushes were replaced. WeWillWin🇬🇧🇺🇸
Post #1027546 10th Mar 2024 9:12pm
Page 6 of 6 <123456
