![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 40 ![]() ![]() |
Question for the room:
Is there a way to "reset" the eco-data / distance to empty on a 2020 110 P400 w/ Gaptool? Something is amiss with mine whereby after I fill up my tank, instead of saying "250 or 300" miles to empty, or whatever, it says something random. Like 50 miles, 60 miles, 100 miles. Etc. I did quite a bit of towing for a month. But, t's now been a couple weeks (5-6 fill ups at the gas station), but it doesn't seem to want to go back to "normal" -- it's still showing unusually very low range as if I'm towing my trailer (heavy) into the wind. The eco-data screens also show dismal mileage etc. The gas gauge reads properly and everything else is normal. Dealer had no idea and said "just wait" but it's ridiculously long at this point... it should be actually showing me a real distance to empty based on recent driving, right? Anyway... don't want to visit dealership again for this as I think it just needs a "master reset" or something and I've got the IID here ready ! |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 109 ![]() ![]() |
I'm pretty sure that step's not necessary. I just emailed myself 2 ccfs, one with "show unsupported" on, and one with it off. They compare identical. |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 ![]() ![]() |
I got the window missing for Dynamic mode figured out. I had the wrong option selected and did not realize it until I compared the 110 to the 130 and saw my mistake. Here is an updated list of changes specific to Dynamic Mode.
EUCD 245 Dynamic 1 Set to Dynamic 1 Content with Configurable Dynamic Mode Screed. I had accidentally set this one to the option that says without vs with. MultiCAN 562 DynamicProgMode Set to Fitted MultiCAN 605 ConfigDynamicMode Set to Fitted MultiCAN 682 DynamicLiteMode Set to Available for Selection Without Timeout MultiCAN 777 Ter Dyn Select in FCPB Set to Rotary used for selection within touch screen I am going to try a few new things for Advanced Tow Assist tomorrow. After comparing the 110 without advance tow assist to the 130 with it here are the settings I am going to try. I figure if I match the 130 it should work. I will report back later but for now here is the list. MultiCAN 579 Advanced Tow Assist. Changing to Tow Assist 2 MultiCAN 505 Towing Aero. Leaving set to not supported MultiCAN 635 Towing. Leaving set to not supported. MultiCAN 696 ATCM TA2. Leaving set to not fitted. MultiCAN 793 TA2 Input. Changing to HVAC Rotary. MultiCAN 795 TA2 Select in FCPB. Changing to Rotary used for selection in FCPB. That is all the CCF’s that have been suggested before in this thread plus new ones as a result of my comparison. Fingers crossed we will see if this works. I made a list today of other items I want to look at and see what happens if things are changed. I will report on those as well as I try them out. |
roccobarocco Member Since: 27 Jun 2023 Location: Ulm Posts: 15 ![]() ![]() |
Thank you for your report. Hopefully, the list will expand with time! Cheers
Well that didn’t work. I matched the settings between the 130 and the 110 and no joy. It is the same as before. I get to the Advance Tow Assist screen but I still can’t select start and it says reserved still. When I cancel out it says auto steer canceled so nothing has changed from before. Back to the drawing/testing board again.
MickD Member Since: 28 Jul 2023 Location: New England Posts: 28 ![]() ![]() |
Bummer, I was hoping you had it
Funny thing is, I don't know that I would ever use the feature, I just want to try it. It's also interesting just trying to get it activated. |
PeteSkeet Member Since: 04 Aug 2023 Location: Houston Posts: 8 ![]() ![]() |
How did you get the paddle shifters enabled? I got them fitted today but no option on IID enables them. I tried MultiCAN-536 GearBoxPaddlesInDrive and changed to "Active in Drive" without any luck. Can't find anything else relevant in IID |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 ![]() ![]() |
Is it possible to see via Live Values how many Ampere is going to the battery while the engine is running? Or even how high the charging level is? I’m here camping in Iceland and after two days standing time the low battery warning is already showing.
Trying to get Dynamic mode selectable via rotary dial instead of just touchscreen.
I believe it is this “ MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen” However, my IIDtool does not show this 777 line. Even if I show unsupported. Ideas? |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
Unfortunately it's not possible yet to enable them with the IID tool, David at Hunters Prestige enabled them for me using Pathfinder Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
There are loads of live values you can see with the tool, but I'm not sure whether the amperage is in there without looking. When I go camping I always just use the cargo door as opening that doesn't seem to wake the whole car up whereas the passenger doors do. I also turn the interior lights off so the whole car isn't lit up when you open the door, this seems to save having as many low battery warnings ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I would drop Patrick an email at gapteam@gap-diagnostic.com Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
scrub that
Alright have to look into it a bit closer. I do it like you do. Lights out but I need the front doors more often because my wife and I sleep in the car so the back is the bed. I wished the Defender was a bit more heavy duty. Put in a camping mode, have a nice generator, something like a 3500 truck. |
