Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 40 of 109 <123 ... 394041 ... 107108109>
ODPA
United States
Here is a new one I was playing around with. Have not been able to get it working either but maybe others have played and have ideas?
MultiCAN - 636 AdaptDrvBeam. Set to AdaptDrvBeam Disabled. First you have to have the Mayrix LED to be able to activate this from the research I have done. Based on my 110’s CCF listing I have the matrix LED. I changed the setting to enable and nothing. Well nothing other than the ability to turn on and off the auto high beam disappeared. I still have auto lights and high beam assist or whatever just no place to switch on and off in the PIVI anymore. I left it to see if maybe it would magically show up as some have reported with other changes but nothing. Anyone have ideas or info on this?
Post #1003417 9th Aug 2023 5:06am
mmbanf
Italy
HI,
to enable the matrix lights you need to change these parameters:
MultiCAN-679 HeadlightsVariant
Headlamp_Variant_Mid_C ——————to Variant_hight_( A,B,C according to your country)
MultiCAN-636 AdaptDrvBeam
AdaptDrvBeam Disabled ———————to enabled.
MultiCAN-706 Dyn Bending Light
Not fitted———————————————to fitted
MultiCAN-693 ADB Initialisation
Not fitted—————- —————————-to fitted.
on my car when i upgraded, everything worked even with just the first two ccf's.
Your car may have restrictions due to the regulations in your country.
Marco
Post #1003444 9th Aug 2023 11:01am
ODPA
United States
Marco
Thank you. I printed a list of my CCF’s and had been going through them and listing everything that looked like it was related to the headlights or ADB. Was just not sure where to start messing around. I will try MultiCAN 679 first to see if that works then others if needed. I also wondered about country restrictions. From all the reading on different changes I initially believed I would not be able to get global close to work from the remote here in North America. It sounded like I would be able to use the function using the exterior door lock buttons only. But after some more looking and trial of a few setting I was able to make it work despite it being restricted in our market I believe. So I am hopeful that I will be able to get this working as well.
Scott
Post #1003460 9th Aug 2023 1:32pm
mmbanf
Italy
Well!
remember to reset the pivi, at least twice. Thumbs Up
Post #1003463 9th Aug 2023 1:43pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Scott are Matrix light legal in the USA? I thought they weren't so would be surprised that Land Rover would fit the Matrix lamps instead of just premium LED as there is quite a price difference between the two.
If you have them enabled you should get this switch in the pivi settings
To test that they are working you will need to find a place with no street lamps and total darkness, when you go over a certain speed the blue main beam light should come on and remain on whilst there is no light. If you get a car coming towards you you should be able to see sections of the light dropping away so as to not blind the oncoming car, and the main beam light will remain on while they are working.
If you want to drop me a PM with your email address I'll email over a copy of my ccf which has the matrix lights from the factory for you to compare Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1003470 9th Aug 2023 2:26pm
Ratledge
United States 2016 Defender 90 300 Tdi SW Auto Stornoway Grey
Ian, I should be asking this by PM, but since I am too new here, it won't let me.
Is there a list of things known to work? I just got my unit from Lucky8 and ready to activate.
Post #1003546 9th Aug 2023 11:40pm
Hairy Dan
Hi and welcome to the forum, everything is in this post but spread out, if I have time tomorrow I'll try and collate it and post an updated list Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1003549 9th Aug 2023 11:59pm
ODPA
United States
Sent you a PM, looking forward to seeing the differences. As for the matrix lights I was initially thinking the exact same thing that they were not fitted for the US market. I then saw a post somewhere else a few days ago that said they were coming to the states and that post was older. I was only thinking I did have them in that my CCF EUCD-014 Headlights, Type. Is listed as Matrix LED AFS123/IHB. I have not looked at the other options in this CCF but I assumed that meant I had the Matrix LED lights. I enabled the ADB to enabled the other night and I did not get that screen as I had hoped. I did also restart the PIVI a few times and tested on a dark road as I live out of town away from lights. No joy. I plan to try a few of the other options suggested to see if I can make it work or not. Guess we will find out if I actually have the Matrix or not. No issue if not just something fun to try and figure out.
Post #1003551 10th Aug 2023 2:03am
Philipp1601
Germany
Problem with MY2024 CCF file
I a new owner of a IID-Tool BT I bought from ExpeditionParts in Germany.
The IID-Tool BT was delivered today, I updated it to 4.00.00 build 3034.
The car is brand new, too. It is a 2024 Defender 110 D250 XS.
btw:
There are some problems with activating the „inControl“ service of the car, the dealer is trying to find out with LR. So the car is not yet activated. It seems this is not the only car that does not activate, the activation procedure was changed, there is a problem with LR.
In the meantime I tried to code the CCF file to unlock some features. I started with one of the simpler ones:
I tried to activate the wifi hotspot by
MultiCAN-814 IVIWiFiHotspot
Standard: Not fitted
Changed to: Internal WiFi Hotspot fitted
When I tried to upload the changes to the car it said:
„CCF version not yet supported“
and the app fell back to the main menu. Any other CCF-change ends the same.
Can one of you help me with the problem?
Is anybody else suffering the activation problems with LR?
Thank you
Philipp
Post #1003559 10th Aug 2023 6:44am
mmbanf
Italy
Hi Scott,
to understand if you have matrix lights it's very simple, you have to physically look at the front light when you open the bonnet.
There is a white label with the code of the lighthouse, look at the absorption watts,
this is a matrix label:
this instead a premium label:
so if you have matrix headlights, setting the exact ccf everything will work, if you don't have matrix headlights, the adb key will appear on the pivi, but the headlights won't work adaptively.
Marco
Post #1003561 10th Aug 2023 6:55am
mmbanf
Italy
Re: Problem with MY CCF file
btw:
Thank you
Philipp
HI,
I think Patrick should be heard, (now I'm on vacation until 28/08. )
only thing that comes to mind, are you logged in to get full functionality on the tool on your chassis number? otherwise you have no access to ccf encryption and reduced functionality.
Marco
Post #1003564 10th Aug 2023 7:18am
Philipp1601
Germany
Thank you for your reply, Marco,
I already activated the tool and locked it to my car's VIN.
So it should work, I think.
greetings
Philipp
Post #1003577 10th Aug 2023 9:29am
Hairy Dan
As Marco has said drop GAP an email
gapteam@gap-diagnostic.com Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1003586 10th Aug 2023 11:53am
Hairy Dan
I have tried to collate all the known working settings into this post, if anybody spots a mistake or has an addition to make just shout Thumbs Up
- Activate WIFI/WLAN Hotspot
- Change Splash Screen to "Defender 007"
EUCD-205 Racing Sub Brand
Standard: Mainstream Vehicle
Changed to: LTD 007
- Dynamic Mode
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
-Remember Stop/start setting
MultiCAN-566
MHLastUserMode = Enabled
For Walk away locking and Approach unlocking the general rule is that it is only available on MY2023 onward, if you don’t have a locking fuel cap you can enable both. You will also have to go into your centre screen setting and switch it on. Some people with earlier cars have got this to work but it is a bit of a lottery Confused
-WalkAwayLocking
MultiCAN-505
Change it to Current: Enabled
-Approach unlocking
MultiCAN-807 Approach Unlocking
Disabled
Change to Enabled
-Modify signature LEDs behavior
MultiCAN-463 DRLBehWhilstDIsAct
Current: Turn Off
New: No Action
MultiCAN-465 DRLBehWhHazardsAct
Current: Turn Off
New: No Action
This setting is to keep them on while the turn signals or hazard lights are operating.
- The subwoofer was installed in the base model, but wasn't enabled.
EUCD-121 Subwoofer
Standard: Without Subwoofer
Changed to: Subwoofer
-Enable All Microphones
EUCD-126 Microphone = Four Microphones (Two Front & Two Rear)
Standard: Microphone (Driver Only)
- Disbale Seatbelt Reminder
MultiCAN-717 Front Belt Minder
Beltminder Fully OFF
- MultiCAN-770 Remote Release Tailgate
Enabled
This will make the rear door pop open when you press the button on the key fob
-MultiCAN-723 Gloabal open/close
MultiCAN 723 SMRF Global Close - changed to Enabled
MulitCAN 719 CDL Global Close - changed to Enabled
MultiCAN 719 CDL Global Open - changed to Enabled
EUCD 184 Global Open/Close - changed to Global Open/Close Doors + Sunroof
- Configurable TR
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout
A couple of videos that should help new users
How to enable the James Bond Screen
How to email a copy of your CCF File to yourself
 Cheers Ian
Kielder 4x4 Safari
Post #1003591 10th Aug 2023 12:06pm
MickD
United States
That's great. I wished I had that when I first started. It really should be stickied and not buried on page 40 of a thread.
One thing I don't see in your list is fogs with high beams. I read that this would do it but it didn't work for me.
EUCD-018 Foglight Function
Foglight without restrictions
Post #1003602 10th Aug 2023 1:11pm
