Home > Puma (Tdci) > Does anyone use a Radiator Muff during Winter?
Page 2 of 9 <123456789>
markb110
Piece of cardboard like the old days Thumbs Up
Ok I am going to say it as others must have been thinking it (smutty lot the you are)
Ok here goes - show us some pictures of your muff Shocked
Rolling with laughter
Mark
Post #104431 4th Dec 2011 7:51am
ZeDefender
Mark
Hadn't even occurred to me (sniff) Whistle Tell someone you love them today because life is short.
Post #104433 4th Dec 2011 8:22am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Last year I used a big piece of card covered in Bacofoil, and it did make an improvement to the warm up time.
Pete
Post #104438 4th Dec 2011 8:38am
ZeDefender
Pete
Was that on a Puma? Tell someone you love them today because life is short.
Post #104439 4th Dec 2011 8:53am
XS Pete
Sure was. I only have a short drive to work, so once we get into December I need all the warm up help I can get.
Pete
Post #104445 4th Dec 2011 9:19am
22900013A
I quite fancy one of these as I also sometime do very short runs in the early hours and the engine does not get chance to warm up. Is the exmoor one the best or are there other options for a slightly more restricted budget? 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #104446 4th Dec 2011 9:28am
I bought an Exmoor Trim one a little while ago but was so disappointed with the way it fits that I sent it back.
It works by clipping over the grill itself, but I found that to be tight enough not to fall off, it actually distorts the grill. The clips that secure it aren't very secure either.
Another drawback is that it would be very susceptible to being pinched!
There's got to be a better solution for nearly £50 Rolling Eyes Darren
Post #104451 4th Dec 2011 9:53am
22900013A
Thats no good if it damages the grille. I have seen ex-army ones but they are very, well, army to look at. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #104454 4th Dec 2011 10:01am
22900013A
This is what ebay brings up - http://www.ebay.co.uk/sch/i.html?_nkw=land...m270.l1313
But no indication of how these attach, or indeed if fixings are supplied. Don't like the sound of the ones attached with cable ties... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #104461 4th Dec 2011 10:25am
JWL
Am I missing a point here but, in my mind just open the bonnet, whip out your pozidrive screwdriver and take off the plastic panel off the top of the radiators(4 screw fastners, TD5) Place a fabric or sheet material to block off part of the coolant radiator inbetween the two radiators. That way there is nothing to be nicked off the front and at least you are still allowing air flow to the intercooler, may be a bit buffered as it is choked from behind. Just a thought Wink
Post #104464 4th Dec 2011 10:40am
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
I tried what JWL suggests last year, and indeed the defender warmed up more quickly.
What I found was that once warm the viscous fan just stayed on - making noise and using fuel Exclamation
In the end I resorted to returning to normal.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #104572 4th Dec 2011 6:48pm
a key thing here is not to block airflow to the intercooler
Post #104575 4th Dec 2011 6:51pm
JWL
I wasn't suggesting blocking off the whole of the radiator, just reducing the flow through a portion of it.
Post #104582 4th Dec 2011 7:06pm
Lookers Park Royal
I use mine for Lansing in the height of winter as my 300Tdi runs stone-cold at the usual laning speeds.
James Thumbs Up
Post #104585 4th Dec 2011 7:13pm
T1G UP
Steve Thumbs Up
first things first...remove the fan and keep it in the back, then put some card down in front the rad
Post #104591 4th Dec 2011 7:30pm
