Home > Puma (Tdci) > coolant air locking
Page 3 of 6 <123456>
bear100
Just thinking about what a mechanic friend said to me......you have changed your turbo, VCV, water pump, vacuum pump, injectors, bearings, full braking system etc etc then your more than capable of doing the head gasket after all its all nuts and bolts.
would any of you attempt a this yourselves? with a new head? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1059244 2nd Feb 2025 10:19am
ickle
I did mine just over a year ago, the only fiddle I found was forgetting to order new studs for the exhaust flange and trying to get the downpipes to line up with the studs in place (loosened an engine mount in the end) and mine has air con so the evaporator was in the way a bit for access - as its original and known to be a bit delicate I made a thin plywood cover for it for protection.
I'd say it was easier than the clutch and all of the polybushes I've just finished!
Go for it and take your time, we can all help from the comfort of armchairs and log burners!!!!!!
Keith
Post #1059254 2nd Feb 2025 10:45am
bear100
polybushes is on my list too!! Shocked
thanks for the advice, I've been watching this guy, really good to be fair to him, excellent videos.
doesn't look to bad, if these step by step are followed
Tackling this isn't from a finance point of view but more a personal achievement, i like to do as much of the maintenance and upgrades i can with what i have on the driveway. 2023 Defender L663 V8
Post #1059256 2nd Feb 2025 10:56am
ickle
Yes watched those too - great source of info.
On the drive in south Wales in the winter? - can you collect the bits ready and do it when it gets lighter and warmer ? Or do you have a garage you can put the nose of your 110 into?
Im with you on the reasons for doing it, plus you're know its been done properly. I had the clutch done 6 years or so ago by a specialist near Cheltenham, all has been good except the tunnel and floor plates were replaced by what looks like Tek screws so all of the square plastic inserts stripped, there were two cross threaded bolts on the bell housing, wiring looms weren't clipped in place and were chaffed, the cover over the transfer box lever was cracked......
Best of luck
Keith
Post #1059276 2nd Feb 2025 1:24pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
- look at videos but follow the manual religiously, especially torque sequences.
- do not guess at the angles when torquing. Use a torque wrench with angle settings (best) or an angle indicator (fiddly).
- keep wearing parts in the same location and orientation (followers, etc).
- do not reuse torque-to-yield bolts.
- make sure you clean and blow out the threads in the block.
- do not reuse gaskets or o-rings. There's a lot of them so get a kit that includes them all for the best price.
- yes, head gasket thickness matters.
- don't buy aftermarket parts -- by that I mean cheap, no-name stuff. Name-brand, OEM, Land Rover, or Ford.
- since you are in there, reverse flush the heater core. It can make a huge difference.
- same with belts, idlers, water pump, and hoses. If they are original, now is the easiest time to change them?
- Ford timing chain kits are cheap. Change the sprockets, guides and tensioner, as well.
- you do not need the timing tools. I bought them and ended up using drill bits and what not (see videos) instead as they worked better than what was in the kit (??!!)
- thought about deleting the EGR? Easy to do it now but you'll have to get it mapped out as well.
Post #1059280 2nd Feb 2025 2:30pm
bear100
Well I've decided to do it myself Shocked
just ordering in some bits and tools i need...angle indicator etc
just thinking about head gasket thickness? what sizes are there and what to fit? when the head was done last year the head went to be skimmed but I'm now going to fit a new head so not entirely sure what thickness to fit? 2023 Defender L663 V8
Post #1060696 16th Feb 2025 3:24pm
jbcollier
Head gasket thickness is based on piston protrusion. As you are just changing the head, use the same spec head gasket as you have fitted now.
Post #1060699 16th Feb 2025 3:53pm
ickle
I think there's 3 different ones indicated by tabs - as JB says if you fit the same again, nothing is going to hit.
Post #1060700 16th Feb 2025 4:38pm
bear100
Ahh ok, I see! Makes sense now.
So when the head is off the existing will have a number of holes 1-3 so replace with the same m, assuming the mechanic who fitted it originally did measure it and fitted the correct one and not just the thickest one 2023 Defender L663 V8
Post #1060701 16th Feb 2025 4:46pm
jbcollier
If you are not sure, you could measure the piston protrusion. There's a procedure in the manual.
Post #1060703 16th Feb 2025 4:56pm
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
You can identify the thickness before you take the head off. There is a tab sticking out with 1-3 holes in it.
You can see them over the vacuum pump in the lower image.
Post #1060753 17th Feb 2025 10:32am
bear100
Thanks, i hadn't realised that Thumbs Up
Weirdly I'm looking forward to to doing this Very Happy
What else should i do or replace while I'm in there?
What makes are best quality/ eg head gasket kit, sealants etc?
Should i reuse the original bolts or buy new? (injector stretch bolts I've got sorted) 2023 Defender L663 V8
Post #1061646 1st Mar 2025 10:17am
ickle
I bought everything from Turners in one hit superb service & quality.
Good luck
Keith
Post #1061658 1st Mar 2025 1:31pm
jbcollier
Head bolts are also single use.
When snugging up the cam/follower carrier, got slowly, a half turn at a time. It is very common to crack the carrier.
Apply oil or engine assembly lube to cams, valves and followers. Also apply oil to the timing chain. You do not want moving parts to be dry on start up.
Post #1061669 1st Mar 2025 3:02pm
bear100
ordered lots of bits from Turners Very Happy
the front timing cover is this sealed on and if so what with? do i need a new one? it had a new one last year when the mech fitted the head gasket
Thanks for the tips! 2023 Defender L663 V8
Post #1062826 13th Mar 2025 7:33pm
