Home > My Defender > My 90 - Rolling resto on a tight budget
Page 6 of 8 <12345678>
frenchy
Luvin the thread 007,
How are you getting on with your battery tray??
Had my 300tdi for a week now and have just removed the battery. Oh dear....... Shocked
Its been held in place by not much more than good will.
Whats your plan, cutting and welding?
Would Isopon & Aluminium mesh be good enough as a short tem fix until MOT time:oops:
Post #130284 10th Mar 2012 11:29am
mymini007
1986 Defender 90 200 Tdi HT Java Black
thanks for the positive comments guys, keeps me going Laughing
I am going to buy a battery tray, MOT is a good 9 months away, and its not too bad at the moment
I am going to get one of these. http://www.yrm-metal-solutions.co.uk/021-n...x-13-p.asp
I am led to believe they can just be riveted in!
I am going to make my own inner van sides, Was going to put windows in, but I think I am just going to keep it as a van, as I have had a lot of use from it already.
6mm ply covered in acoustic carpet should do the trick.
I have got my steering guard to try and fit today, and some more hoses to replace.
RRUK, yours is looking great, you are inspiring me to get on too. But i dont have the budget you are working with, hence the blue peter approach to mine Rolling with laughter
I have just thought of a name for it......... You cant polish a turd!
But you can roll it in glitter Smile
2006 Mercedes Benz CDI320
2001 Volkswagon Caddy Van 1.9 SDi
1993 Nissan Patrol 4.2 TD
1986 90 200tdi - SOLD
1990 Mini mayfair (highly modified) - FOR SALE
Post #130290 10th Mar 2012 12:29pm
WarPig
mymini007 wrote:
Nice Raptor dash Thumbs Up
Did it come pre-drilled to your spec, or did you drill out for the switches etc yourself?
Post #130303 10th Mar 2012 1:45pm
mymini007
There are set templates, and I just added the hazard switch. wish I had not bothered with the extra holes for the dials. As i dont think I am going to use them.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  You cant polish a turd!
Post #130316 10th Mar 2012 2:31pm
mymini007
More shiny hoses
Top rad hose and and the top IC hose..
When i get a chance I might polish up the alloy Cool
This needs a clean up and fitting
I need to have a play with this, not sure how i am going to connect it at the moment.
Finally fitted the checker plate wing top, still need to paint the other side. And I really need to get my arse in gear and paint the bonnet and bulkhead.
Embarassed
Not bad for a couple of hours, time to go and watch the rugby. 8)
Post #130320 10th Mar 2012 2:53pm
frenchy
Thanks for the battery box info. Thumbs Up
Do you believe that they are riveted in on top of the existing or do you have to cut out the existing first??
Any one got any photos ?
Go on then........whats it called Question Question Question
Post #130322 10th Mar 2012 3:19pm
mymini007
If you google battery box fitting, I found a couple of threads this was the best one http://www.landyzone.co.uk/lz/f7/new-battery-tray-154812.html
So cut out the old and rivet in the new.
...........Peter, as in blue peter.........I'll get my coat. You cant polish a turd!
Post #130328 10th Mar 2012 3:53pm
frenchy
T A X I !!!!!!!!!! Laughing
Post #130341 10th Mar 2012 5:46pm
mymini007
Just been out for a test drive and it feels a lot more responsive, not surprising really as the IC pipe was being held on with cable ties, so must have been loosing boost.
I have just had a look at the upper rear ball joint and as I thought its knocking so that needs to be replaced, but I knew that. As it knocks every time I change gear. Rolling Eyes You cant polish a turd!
Post #130343 10th Mar 2012 5:55pm
mymini007
Just sold my wheels. Gonna get some ATs, as the road noise is driving me nuts Cool You cant polish a turd!
Post #130434 10th Mar 2012 10:13pm
mymini007
Collecting new wheels tonight,
Freestyles from a Discovery ES, (grey inserts)
I have become addicted to silicone.
Will be getting a the full collant kit in blue for the next purchace.
This one probably http://www.rimmerbros.co.uk/Item--i-RD1266...edium=feed
So these are the next ones to go.
Jet washed the engine on saturday so on my drive to work today I was able to see if the hose fix had cured the oil leak. And I am happy to report that it seems to have worked, It also pulls so much better, I can get to 60 now with no effort at all. Where as before I was struggling to get to 50 and keep it there.
Post #130691 12th Mar 2012 9:44am
frenchy
007,
never mind "peter", she'll have to be called "pammy"
cos' when you said.............
mymini007 wrote:
I have become addicted to silicone........
I thought you meant
Whistle
Post #130826 12th Mar 2012 8:06pm
mymini007
frenchy wrote:
007,
I thought you meant
Whistle
007 likes this Thumbs Up
Pamela it is then Thumbs Up - Pamela Landy............Bourne Identity?.........COAT! You cant polish a turd!
Post #130891 12th Mar 2012 10:25pm
frenchy
Thumbs Up
Post #130907 13th Mar 2012 12:04am
mymini007
New feet and shoes fitted.
£100 + Original wheels Sold
£100 - Chunky Wheels and tyres Bought
£250 + Chunky wheels and tyres Sold
£280 - BFG ATs and Freestyle wheels Bought
So New wheels cost me £30 Mr. Green
Post #131119 13th Mar 2012 8:54pm
