Home > My Defender > My 90 - Rolling resto on a tight budget |
mymini007 Member Since: 10 Nov 2011 Location: Chippenham Posts: 273 |
I was thinking maybe silver, but I think black will look better. Its green at the moment (Algae and moss) |
11th Feb 2012 2:53pm |
Should be rolling by the weekend,
The dash is in, all the 'lectrics now work. It starts and runs, Just need some wheel spacers as the fronts are catching on full lock. |
22nd Feb 2012 7:54pm |
Woohoo, all insured and ready to go
25th Feb 2012 11:12am |
Its back yaaay!!!
Click image to enlarge New Dash Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
25th Feb 2012 3:20pm |
Having second thoughts on the black.
Saw a Tahiti blue one today, it looked a-may-zing! |
26th Feb 2012 3:47pm |
Dont like the new wheels at all.
Its horrible to drive, it bounces and skips all over the place, this may not help, but it also has a wobble at about 40 mph (balance maybe) but compared to my old RR wheels and tyre combo these are horrid really does not feel safe over about 50 mph, used to be fine on the m'way good for 70 mph easy. |
27th Feb 2012 9:34am |
v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206 |
what axle have you on the back - a standard defender one with drum brakes. If so - I'm not sure that the style of alloys from the Disco wheels that I thinks these are will sit square on the hub - hence the wobble worth checking that they are all sitting right on the hubs
I could be totally wrong and I'm sure others will be able to confirm. On my old 90 which was an e plate - i had the axle swapped to one with disc brakes so I could get the alloys on - I was running disco 1 alloys with insa turbo and it was steady up to 60 - above that and the chunky tyres it got a bit light I know it may sound silly but check the true pressures on the muds - they may be all over the place if they were used off road before. Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
27th Feb 2012 9:42am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Lookin good, will all be worth it in the end
27th Feb 2012 9:53am |
I have got drums on the back yes. I will check both, unfortunately I have sold the old ones, so either way I will have to make do for now. Will check the tyre pressures when I get home. To be fair, the wobble feels like its coming from the front as it shakes the steering wheel, once i get to 50 it seems to stop. I will be fitting some 30mm spacers. as the fronts do catch a little on full lock, so this may sort the problem if the wheel is not sitting square. |
27th Feb 2012 9:58am |
Now the wiring has been completed, I have a few more bits to be getting on with.
List:- Sort wheel wobble Fix leaky rear drum Replace hoses that are leaking for samco silicone blue. 30mm spacers for the wheels New battery tray as mine is rotten (not sure how it got through the MOT) Finish of black paint. New rear door. New door liners/cards (front) Build tool box/speaker box Fit rear seats Sound proof rear van sides and roof. Fit replacement seats with risers Replace front bumper Paint roof Paint roof rack Replace steering wheel Repair Front doors Replace front door hinges Replace door seals all round Fit side steps Fit ladder to enable roof rack use Fit swing away wheel carrier Change door lock barrels so they are all the same. And thats just quickly off the top of my head, I am sure there is more Not sure what it is about this little truck, but despite all its issues, I really like driving it. |
28th Feb 2012 12:10pm |
Fitting spaacers may stop this - it will stop rubbing when on full circle, but it will also allow the alloy to sit true on the hub - Do you know anyone with spacers that can let you try before you commit to spending money? I'd suggest a couple of things other checks 1. swap wheels around - mark them first - you may find that there is a badly buckled wheel or well out of balance - it is a pain but then you can at least narrow down if the issue is front or back/ 2. Check the steering bar is straight and not bent - i had this happen in the past must have hit on a rock and it had a slight kink in it but it was enough to cause a few scary moments on the road at speed. 3. Any play in the track rod ends - When were all the bushes last replaced - - its an relatively cheap and easy fix - worth doing if in any doubt - There may be a combination of things causing the wobble good luck and keep us posted - Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
28th Feb 2012 1:31pm |
Where are they and how do i do it? |
28th Feb 2012 1:46pm |
Just been to get the wheels balanced, but left the locking key in the garage. But thats the first option. I was going to buy 2nd hand spacers from ebay and if it didn't work I can just sell em on again. Bushes are on the list too now then I had planned that anyway Its only done about 100 miles since the MOT so I hope the TRE would be ok but a worthwhile check I thinkg I am pretty sure its a wheel issue as i had no problems prior to switching the wheels over. Thanks for the tips |
28th Feb 2012 1:50pm |
Just had a look at the stop lock nut, or not as the case may be totally caked in crap, I would say 26 years worth by the looks of things.
Whats the best way to clean them off, Jet wash and gunk? Sort wheel wobble Fix leaky rear drum Clean up swivel joints and replace seals if required Replace hoses that are leaking for samco silicone blue. 30mm spacers for the wheels New battery tray as mine is rotten (not sure how it got through the MOT) Finish of black paint. New rear door. New door liners/cards (front) Build tool box/speaker box Fit rear seats Sound proof rear van sides and roof. Fit replacement seats with risers Replace front bumper Paint roof Paint roof rack Replace steering wheel Repair Front doors Replace front door hinges Replace door seals all round Fit side steps Fit ladder to enable roof rack use Fit swing away wheel carrier Change door lock barrels so they are all the same. Whats the best way to clean them off, Jet wash and gunk? Click image to enlarge Click image to enlarge Looks like i have a brake drum leaking also! Click image to enlarge[/i] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by mymini007 on 28th Feb 2012 4:00pm. Edited 4 times in total |
28th Feb 2012 3:47pm |
