Home > My Defender > My 90 - Rolling resto on a tight budget
Page 5 of 8 <12345678>
RRUK
I'd use a wire brush and then loads of WD40 and more wire brushing, then more WD40, let it penetrate fully 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #127458 28th Feb 2012 3:51pm
Martin
Site Admin
Alloys go over drums just fine, had Tornados on my 90 for 12 years without an issue:
http://www.web-rover.co.uk/nav.php?p=articles/alloys
But do check they are sat on the hubs correctly.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #127461 28th Feb 2012 3:54pm
mymini007
1986 Defender 90 200 Tdi HT Java Black
Sort wheel wobble (SORTED)
Turns out that one wheel on the front was 140g out of balance, and the other was 190g out, thats what was causing the wobble
Fix leaky rear drum
Clean up swivel joints and replace seals if required
Replace hoses that are leaking for samco silicone blue.
30mm spacers for the wheels
New battery tray as mine is rotten (not sure how it got through the MOT)
Finish of black paint.
New rear door.
New door liners/cards (front)
Build tool box/speaker box
Fit rear seats
Sound proof rear van sides and roof.
Fit replacement seats with risers
Replace front bumper
Paint roof
Paint roof rack
Replace steering wheel
Repair Front doors
Replace front door hinges
Replace door seals all round
Fit side steps
Fit ladder to enable roof rack use
Fit swing away wheel carrier
Change door lock barrels so they are all the same.
Post #127986 1st Mar 2012 2:23pm
Zagato
Go easy pressure washing your swivels and blasting grit up into the seals.
Their are two trains of thought on swivels. Those that oil/grease the balls to reduce corrosion and those that leave them dry so grit/dirt doesn't stick to the ball and get under the seal making it abrasive.
Post #128044 1st Mar 2012 6:10pm
mymini007
I have found a new form of sound deadening, 250kg of logs in the back, made a massive difference I could actually hear the radio on the way home.
On a separate note, should I get rid of the roof rack. I dont use it! Idea Question
Post #128934 5th Mar 2012 6:40pm
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
mymini007 wrote:
.On a separate note, should I get rid of the roof rack. I dont use it! Idea Question
How much do you want mate? Smile Good things come to the wild and free
Post #128946 5th Mar 2012 7:10pm
RRUK
Get shot of it then you can clean the roof! 2016 D4 HSE
Post #128949 5th Mar 2012 7:18pm
mymini007
Make me an offer. Whistle
But just so you know, it may need a bit of fettling. as its a home made one, and the brackets its been fixed to are welded on Confused
It will ne cheaper than any other roof rack thats for sure. Laughing
Post #129135 6th Mar 2012 10:10am
mymini007
Just bought some tomb raider side steps for £50 Mr. Green
I like the tomb raider look Idea You cant polish a turd!
But you can roll it in glitter Smile
2006 Mercedes Benz CDI320
2001 Volkswagon Caddy Van 1.9 SDi
1993 Nissan Patrol 4.2 TD
1986 90 200tdi - SOLD
1990 Mini mayfair (highly modified) - FOR SALE
Post #129718 8th Mar 2012 12:30pm
Zagato
What are Tomb Raider side steps Confused
Post #129736 8th Mar 2012 1:21pm
RRUK
I think they are the tubular ones with chequer plate tops 2016 D4 HSE
Post #129737 8th Mar 2012 1:23pm
mymini007
Thumbs Up Thumbs Up Thumbs Up Thays the ones!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  You cant polish a turd!
Post #129757 8th Mar 2012 2:06pm
mymini007
A couple of other bits sourced thanks to TTF
Steering guard Check
Raised air intake Check You cant polish a turd!
Post #129927 8th Mar 2012 9:17pm
mymini007
Started the engine bay tidy up today, the I think the intercooler pipe is leaking so that was the first job.
Before
After
I chopped up the old IC pipe and added some new samco bends, and some new ally pipe, its a bit close to the alternator but with a bit of jiggling I should be able to move it away. I think thats where all the oil is coming from, but not sure, I think the dodgy welds don't help. there was not an alarming amount of oil in the pipe but if its under pressure I am guessing its spraying all over the place.
Just the IC top hose to sort and some new belts, and a few more blue hoses.
Note the IC top hose is held on with cable ties not jubilee clips :shock:
Post #130158 9th Mar 2012 7:03pm
RRUK
Good progress, keep it going, loved reading your progress, has spurred me on doing mine. 2016 D4 HSE
Post #130203 9th Mar 2012 9:44pm
