![]() | Home > Technical > are all ABS CV joints the same (repairing a puma 2011) |
ralsim Member Since: 16 May 2024 Location: wales Posts: 5 ![]() ![]() ![]() |
are all ABS CV joints the same??
I've order and received a Britpart CV joint https://www.lrdirect.com/tdj000010-supplie...d-britpart just took everything apart and feel its not the same the one that was in there was a GKN one https://maltings4x4store.co.uk/driveshafts...tdb500280/ the Half shaft is fine but the CV is chewed to bits so didnt want to spend on the whole thing. cracks in the crown that hold the big ball bearings. I might just return the Britpart and order the full halfshaft and joint from GKN if I can find somewhere with stock current daily defender puma 110 xs 2.4 Current Project Series I 1.6 2 door past landrover 110 1983 v8 stage 3 engine with ported heads, ported polished inlet manifold balanced crank, large trumpets, top hat liners large valves ported plenum with large butterfly sadly stolen |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3520 ![]() ![]() ![]() |
Worth a read:
https://www.defender2.net/forum/topic78224.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
this looks interesting might as well do left and right and feel a little safer for a few years
https://ashcroft-transmissions.co.uk/product/cv-with-abs-pair/ https://ashcroft-transmissions.co.uk/product/front-shafts/ for the little more than the standard puma single GKN shaft current daily defender puma 110 xs 2.4 Current Project Series I 1.6 2 door past landrover 110 1983 v8 stage 3 engine with ported heads, ported polished inlet manifold balanced crank, large trumpets, top hat liners large valves ported plenum with large butterfly sadly stolen |
