Home > Technical > are all ABS CV joints the same (repairing a puma 2011)
ralsim
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Santorini Black
are all ABS CV joints the same??
I've order and received a Britpart CV joint
https://www.lrdirect.com/tdj000010-supplie...d-britpart
just took everything apart and feel its not the same the one that was in there was a GKN one
https://maltings4x4store.co.uk/driveshafts...tdb500280/
the Half shaft is fine but the CV is chewed to bits so didnt want to spend on the whole thing. cracks in the crown that hold the big ball bearings.
I might just return the Britpart and order the full halfshaft and joint from GKN if I can find somewhere with stock current daily defender puma 110 xs 2.4
Current Project Series I 1.6 2 door
past
landrover 110 1983 v8 stage 3 engine with ported heads, ported polished inlet manifold balanced crank, large trumpets, top hat liners large valves ported plenum with large butterfly sadly stolen
Post #1045214 8th Sep 2024 1:48pm
Dinnu
Worth a read:
https://www.defender2.net/forum/topic78224.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1045217 8th Sep 2024 2:25pm
ralsim
Thanks this is what I needed
"So finally new TD5 CV joint arrived. I can now confirm that it doesn’t fit the Puma shaft.
The opening into the CV joint is a lot smaller than the Puma shaft.
I am now just going to order a TD5 halfshaft so I can replace seperately in the future.
shame as I spent all morning getting it off the half shaft
[/img] current daily defender puma 110 xs 2.4
past
Post #1045218 8th Sep 2024 2:40pm
ralsim
this looks interesting might as well do left and right and feel a little safer for a few years
https://ashcroft-transmissions.co.uk/product/cv-with-abs-pair/
https://ashcroft-transmissions.co.uk/product/front-shafts/
for the little more than the standard puma single GKN shaft current daily defender puma 110 xs 2.4
past
Post #1045219 8th Sep 2024 2:55pm
