![]() | Home > Puma (Tdci) > 3rd brake light element in glass |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 ![]() ![]() ![]() |
Think this is a common issue, I ran a wire from the spade connector at the bottom, tucked under the window seal all the way around to the light fitting at the top to bypass the problem. Works well and almost invisible.
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 250 ![]() ![]() ![]() |
Update! the brush on stuff worked a treat! I've put some electrical tape over where the rubber goes so hopefully that will never happen again. 1953 80"
1987 mini city e 2011 90" |
ASBGuernsey Member Since: 14 Jul 2024 Location: Guernsey Posts: 10 ![]() ![]() ![]() |
I bought some sticky copper wiring off amazon - works a treat
