Home > Puma (Tdci) > 3rd brake light element in glass
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
The Rubber seal seems to have rubbed on the element in the rear window glass so the brake light doesn't work. I can't see any marks on it, but 12v stops at this point. Bypassing this point and the bulb illuminates.
In the past on the mini i used the paint on granville electro connector, the paint on stuff and that worked well for the heater element - but will it work for a 21w bulb? 1953 80"
1987 mini city e
2011 90"
Post #1044830 4th Sep 2024 9:32pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Think this is a common issue, I ran a wire from the spade connector at the bottom, tucked under the window seal all the way around to the light fitting at the top to bypass the problem. Works well and almost invisible.
Post #1044834 4th Sep 2024 10:21pm
MR_JAMES
Update! the brush on stuff worked a treat! I've put some electrical tape over where the rubber goes so hopefully that will never happen again. 1953 80"
1987 mini city e
2011 90"
Post #1045250 8th Sep 2024 9:12pm
ASBGuernsey
Guernsey 2012 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I bought some sticky copper wiring off amazon - works a treat
Post #1045628 12th Sep 2024 1:26pm
