Home > Puma (Tdci) > Clutches - Sachs Transit 4x4, LOF, Clutchfix etc. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 798 |
Find a LOF approved LR Specialist and you will have a 12 months warranty on all the LOF parts fitted.
You can go on the LOF website and they have an approved fitters map you can check. 2008 2.4 110 Utility Station Wagon XS. |
21st Jul 2024 5:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20265 |
Sachs in mine aka the Transit 4x4 clutch, it’s uprated to a good weight carrying capacity.
I’m happy with it, it feels stronger than the factory offering and isn’t heavy, slips less. I’m pleased with it, if you have a 2.4 you can use the later 2.2 slave and associated 2.2 bleed valve etc with it. |
21st Jul 2024 6:08pm |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 257 |
Hi Bluest
I fitted the Sachs Transit 4x4 clutch about six months ago, very happy with it and agree with custom90 comments. |
21st Jul 2024 7:20pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4194 |
Thanks, worth knowing 2007 110 TDCi Station Wagon XS |
21st Jul 2024 7:35pm |
Sounds promising. Bizarrely, Amazon of all places for a very good price. 2007 110 TDCi Station Wagon XS |
21st Jul 2024 7:42pm |
Esben Kold Member Since: 14 Oct 2023 Location: Horsens Posts: 10 |
I replaced the original with a LOF powerspec. The pedal is not any heavier performs super smooth. I have only done 10k km’s so I do not know how it is in terms of longevity.
The parts seemed well made and in my opinion of superior quality, when compared to the original parts that came out. |
21st Jul 2024 7:43pm |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 207 |
I have had an LOF Powerspec in for 3 years now. I find it is a big improvement over the original LR clutch especially off road or when loaded and towing, with it being far more tractable from stationary (no slip). I do get some rattle when in neutral which I believe is the gearbox idler shaft and due to the stiffer clutch springs.
I currently have an LOF pedal spring fitted as well, which makes the pedal lighter but not too much. |
22nd Jul 2024 12:31pm |
Can I just confirm, is the Sachs a straightforward bolt-in fit to the standard Defender? No other changes required? 2007 110 TDCi Station Wagon XS |
22nd Jul 2024 3:57pm |
Yes, direct fit no problems at all just like all other options.
It suits the MT82 6speed transmission and Ford Duratorque both 2.4 and 2.2L. (Which is the Defender Puma). It was fitted to the Ford Transit 4x4, which had the same gearbox and engine. Regards the Transit 4x4 and its payload etc Blackwolf on here knows more about it, but it is a heavy duty option and very good. It’s what I have, plus the later 2.2 slave, and bleed valve etc. I’ve just come back today from a 110 mile round trip, very pleased with it. So the Sachs / Transit 4x4 clutch will fit straight in a 2007 to 2016 Puma no problem at all. |
22nd Jul 2024 5:18pm |
Parts list which I previously saved :
1x SACHS 3000 950 727 Clutch Kit. (Fixings will be required to fit). 1x Land Rover Genuine LR068979 Concentric Slave Cylinder / Bearing. (Late Type). 3x Land Rover Genuine UYP500070 Replacement Slave Fixings. 1x Land Rover Genuine LR068981 Clutch Slave Adaptor. (Late Type). 1x Land Rover Genuine LR068982 Clutch Slave Valve. (Late Type) 1x LUK OEM Spigot bearing LR004390 (LR004390G) 1x Land Rover Genuine Crankshaft Oil Seal LR020610 (May be needed, leave alone if it is not leaking though). https://www.autodoc.co.uk/sachs/7428173 |
22nd Jul 2024 5:35pm |
Great thanks, I've ordered the Sachs clutch. I am not fitting it as just haven't got the time and I haven't done it before. It's going into Defender specialist, hopefully next week if the clutch comes and I can sort recovery. Good point on the crank seal as it is leaking. Am having a LOF adapter shaft at the same time. 2007 110 TDCi Station Wagon XS
22nd Jul 2024 5:46pm |
There is the adaptor shaft yeah, mine was fine (genuine) but has always been lubed. I have a new flywheel as well, kept safe but again wasn’t needed when mine was done. |
22nd Jul 2024 6:01pm |
Definitely do the 2.2 Puma slave cylinder upgrade while the box is apart. 2008 2.4 110 Utility Station Wagon XS.
25th Jul 2024 1:34pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
I have a Clutchfix HD one, maybe 12000 miles on it now, but despite not having had any really hard use it makes a rattle worse than the original when everything is hot. Seems OK when cold.
Can't say I would bother again, but having pre-emptively fitted one new HD clutch "so I wouldn't have any problems" (ha) I don't intend to take the gearbox out again to do the same. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
25th Jul 2024 3:08pm |
