Home > Technical > Can a single cab headlining fit in a hard top 90? |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10853 |
As you say the back part is different in a 90 van to a pick up, in the pick up it curves down like this
Click image to enlarge as you can see the line below the speakers is where the headlining finishes and is fixed in place above the rear window Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
24th May 2024 9:18pm |
Blue Blood Member Since: 14 Jun 2022 Location: Shropshire Posts: 126 |
Thanks for that mate, well the one I have seen doesn’t look like that so don’t know if it is a cab one now!! Not sure if this is just a normal front piece that can fit in a normal tin back 90??
Any help would be amazing. |
24th May 2024 9:33pm |
The van ones are straight, they fit tight to the roof and where they fix to in the van which allows the back headlining part to slot over/under the front headlining
https://encrypted-tbn1.gstatic.com/shoppin...EMm7qTDmv8 hope this helps Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
24th May 2024 9:43pm |
Click image to enlarge Sorry the image didn’t attach |
24th May 2024 9:48pm |
I just wanted to know if this would fit a 90 van front part
24th May 2024 9:49pm |
To me it does look like it will fit as it is different to the one in my pic Clayton.
24th May 2024 10:06pm |
Awesome I’m going to go with that answer 😁 thanks for your help all.
24th May 2024 10:15pm |
Glad to help
Let us know how get on with it Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
29th May 2024 7:58pm |
