![]() | Home > Technical > Can a single cab headlining fit in a hard top 90? |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10661 ![]() ![]() |
As you say the back part is different in a 90 van to a pick up, in the pick up it curves down like this
![]() Click image to enlarge as you can see the line below the speakers is where the headlining finishes and is fixed in place above the rear window ![]() Keeper. Clayton. |
Blue Blood Member Since: 14 Jun 2022 Location: Shropshire Posts: 99 ![]() ![]() ![]() |
Thanks for that mate, well the one I have seen doesn’t look like that so don’t know if it is a cab one now!! Not sure if this is just a normal front piece that can fit in a normal tin back 90??
Any help would be amazing. |
The van ones are straight, they fit tight to the roof and where they fix to in the van which allows the back headlining part to slot over/under the front headlining
https://encrypted-tbn1.gstatic.com/shoppin...EMm7qTDmv8 hope this helps ![]() Keeper. Clayton. |
![]() Click image to enlarge Sorry the image didn’t attach |
I just wanted to know if this would fit a 90 van front part
To me it does look like it will fit as it is different to the one in my pic
Awesome I’m going to go with that answer 😁 thanks for your help all.
Glad to help
![]() Let us know how get on with it ![]() Keeper. Clayton. |
