Home > General & Technical (L663) > Climate control question |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3687 |
Didn’t even realise this was a thing! How do you get to the menu?
27th Nov 2023 1:53pm |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 497 |
I wonder if there's an "obnoxious but toasty" setting?
27th Nov 2023 2:04pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1431 |
Everyday is school day.
Didn't know this was a thing. I just push and twiddle things until I get what I want. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
27th Nov 2023 2:14pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2907 |
So l got in the vehicle today and it was 4deg C outside. I turned on the climate but it only produced a gentle flow of air, such as when the fan is on "2"
l checked and it was on "soft & quiet" Turning up the temperature didn't increase the fan speed or really make much difference. To get to the climate settings l have to press the bottom right button on the screen, which brings up all the settings. Then l have to select "climate" and press the bottom left button on the screen, which adds "climate" to the 4 options. lf l don't do that the "climate" option isn't there, replaced by "home screen". So then l press "climate" and under "air flow" change it from "soft & quiet" to "balanced" or "powerful & fast" This then works so long as l don't turn off the climate. Or else it reverts to "soft & quiet" lf someone could tell me a better way to do it, that would be most welcome Last edited by lightning on 27th Nov 2023 5:29pm. Edited 1 time in total |
27th Nov 2023 3:16pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
If you press the fan icon beside the left hand temperature controller down you can manually adjust the fan speed by rotating the bezel.
Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
27th Nov 2023 5:00pm |
But that cancels the "auto" climate
l guess if that's the only way to get the vehicle warm quickly l'll have to do that. |
27th Nov 2023 5:32pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2680 |
The fan will be suppressed until the engine warms up, this is how it’s supposed to work. I guess it’s to avoid drawing heat out of the engine until it’s up to temperature, it’ll be to do with emissions no doubt.
It’s up to temperature within 3-4 miles or so and then the fan kicks in and starts warming the cabin. I use the heated seats to bridge the gap on cold mornings! |
27th Nov 2023 7:59pm |
Thought I was missing something Thats what I do. Turn the temp up / down and use the fan. Works treat. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
27th Nov 2023 8:17pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 160 |
If you tap the settings icon (cog icon bottom left) that takes you into settings, then Apps -> Climate ->Auto Airflow. When I've changed it there it stays on that setting. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
27th Nov 2023 10:02pm |
l figured out what's happening!
When driving l normally select "ECO" on the drive mode. This automatically sets the HVAC to "soft & quiet" l never figured it out until today. lt also turns off the heated seats if they were on. |
28th Nov 2023 11:17am |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 288 |
I nearly always drive in Dynamic mode, but back in the summer I noticed that eco mode reduces the air con a lot.
28th Nov 2023 11:53am |
Ah! That’s new news then! I wonder how much fuel is saved running the fan slower! Feels like clutching at straws!!
28th Nov 2023 7:09pm |
Eco is the one mode I've never used. I like my A/C on al the time. Current vehicle: 2020 Defender 110S
28th Nov 2023 9:57pm |
Its done as a multiplier against all vehicles sold to provide a cumulative C02 benefit for emission regs. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
28th Nov 2023 10:33pm |
