Home > General & Technical (L663) > Climate control question
Page 1 of 3 123>
lightning
The climate control on my Defender always defaults to "soft & quiet"
Which means that if l get into the vehicle on a cold day and turn on the climate, very little happens.
"Balanced" is a much better option but if l set it to that it always seems to be back on "soft & quiet" next time l use it.
Has anyone found anything in the CCF that makes it remember the settings, like you can with the stop/start?
Alternatively
ls it possible to set a climate control memory in your "profile"
Post #1016505 27th Nov 2023 11:40am
Co1
Didn’t even realise this was a thing! How do you get to the menu?
Post #1016518 27th Nov 2023 1:53pm
XplusYplusZ
I wonder if there's an "obnoxious but toasty" setting?
Post #1016521 27th Nov 2023 2:04pm
Moo
Ukraine
Everyday is school day.
Didn't know this was a thing. I just push and twiddle things until I get what I want. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1016522 27th Nov 2023 2:14pm
lightning
So l got in the vehicle today and it was 4deg C outside. I turned on the climate but it only produced a gentle flow of air, such as when the fan is on "2"
l checked and it was on "soft & quiet"
Turning up the temperature didn't increase the fan speed or really make much difference.
To get to the climate settings l have to press the bottom right button on the screen, which brings up all the settings. Then l have to select "climate" and press the bottom left button on the screen, which adds "climate" to the 4 options.
lf l don't do that the "climate" option isn't there, replaced by "home screen". So then l press "climate" and under "air flow" change it from "soft & quiet" to "balanced" or "powerful & fast"
This then works so long as l don't turn off the climate. Or else it reverts to "soft & quiet"
lf someone could tell me a better way to do it, that would be most welcome
Post #1016530 27th Nov 2023 3:16pm
Tim in Scotland
If you press the fan icon beside the left hand temperature controller down you can manually adjust the fan speed by rotating the bezel.
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #1016540 27th Nov 2023 5:00pm
lightning
But that cancels the "auto" climate
l guess if that's the only way to get the vehicle warm quickly l'll have to do that.
Post #1016547 27th Nov 2023 5:32pm
Retroanaconda
The fan will be suppressed until the engine warms up, this is how it’s supposed to work. I guess it’s to avoid drawing heat out of the engine until it’s up to temperature, it’ll be to do with emissions no doubt.
It’s up to temperature within 3-4 miles or so and then the fan kicks in and starts warming the cabin. I use the heated seats to bridge the gap on cold mornings!
Post #1016569 27th Nov 2023 7:59pm
Moo
Ukraine
Thought I was missing something Laughing Thats what I do. Turn the temp up / down and use the fan. Works treat. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1016571 27th Nov 2023 8:17pm
WizzardPrang
If you tap the settings icon (cog icon bottom left) that takes you into settings, then Apps -> Climate ->Auto Airflow. When I've changed it there it stays on that setting. Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1016587 27th Nov 2023 10:02pm
lightning
l figured out what's happening!
When driving l normally select "ECO" on the drive mode. This automatically sets the HVAC to "soft & quiet"
l never figured it out until today. lt also turns off the heated seats if they were on.
Post #1016616 28th Nov 2023 11:17am
Nuclear Nick
I nearly always drive in Dynamic mode, but back in the summer I noticed that eco mode reduces the air con a lot.
Post #1016620 28th Nov 2023 11:53am
Co1
Ah! That’s new news then! I wonder how much fuel is saved running the fan slower! Feels like clutching at straws!!
Post #1016647 28th Nov 2023 7:09pm
WizzardPrang
Eco is the one mode I've never used. I like my A/C on al the time. Current vehicle: 2020 Defender 110S
Insta: wizzardprang
Post #1016663 28th Nov 2023 9:57pm
Moo
Ukraine
Its done as a multiplier against all vehicles sold to provide a cumulative C02 benefit for emission regs. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1016668 28th Nov 2023 10:33pm
Page 1 of 3 123>
