Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 155 |
HI,
to enable the matrix lights you need to change these parameters: MultiCAN-679 HeadlightsVariant Headlamp_Variant_Mid_C ——————to Variant_hight_( A,B,C according to your country) MultiCAN-636 AdaptDrvBeam AdaptDrvBeam Disabled ———————to enabled. MultiCAN-706 Dyn Bending Light Not fitted———————————————to fitted MultiCAN-693 ADB Initialisation Not fitted—————- —————————-to fitted. on my car when i upgraded, everything worked even with just the first two ccf's. Your car may have restrictions due to the regulations in your country. Cheers Marco |
9th Aug 2023 11:01am |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 85 |
Marco
Thank you. I printed a list of my CCF’s and had been going through them and listing everything that looked like it was related to the headlights or ADB. Was just not sure where to start messing around. I will try MultiCAN 679 first to see if that works then others if needed. I also wondered about country restrictions. From all the reading on different changes I initially believed I would not be able to get global close to work from the remote here in North America. It sounded like I would be able to use the function using the exterior door lock buttons only. But after some more looking and trial of a few setting I was able to make it work despite it being restricted in our market I believe. So I am hopeful that I will be able to get this working as well. Scott |
9th Aug 2023 1:32pm |
Well!
remember to reset the pivi, at least twice. |
9th Aug 2023 1:43pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1396 |
Scott are Matrix light legal in the USA? I thought they weren't so would be surprised that Land Rover would fit the Matrix lamps instead of just premium LED as there is quite a price difference between the two.
If you have them enabled you should get this switch in the pivi settings Click image to enlarge To test that they are working you will need to find a place with no street lamps and total darkness, when you go over a certain speed the blue main beam light should come on and remain on whilst there is no light. If you get a car coming towards you you should be able to see sections of the light dropping away so as to not blind the oncoming car, and the main beam light will remain on while they are working. If you want to drop me a PM with your email address I'll email over a copy of my ccf which has the matrix lights from the factory for you to compare Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
9th Aug 2023 2:26pm |
Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28 |
Ian, I should be asking this by PM, but since I am too new here, it won't let me.
Is there a list of things known to work? I just got my unit from Lucky8 and ready to activate. |
9th Aug 2023 11:40pm |
Hi and welcome to the forum, everything is in this post but spread out, if I have time tomorrow I'll try and collate it and post an updated list Cheers Ian
9th Aug 2023 11:59pm |
Sent you a PM, looking forward to seeing the differences. As for the matrix lights I was initially thinking the exact same thing that they were not fitted for the US market. I then saw a post somewhere else a few days ago that said they were coming to the states and that post was older. I was only thinking I did have them in that my CCF EUCD-014 Headlights, Type. Is listed as Matrix LED AFS123/IHB. I have not looked at the other options in this CCF but I assumed that meant I had the Matrix LED lights. I enabled the ADB to enabled the other night and I did not get that screen as I had hoped. I did also restart the PIVI a few times and tested on a dark road as I live out of town away from lights. No joy. I plan to try a few of the other options suggested to see if I can make it work or not. Guess we will find out if I actually have the Matrix or not. No issue if not just something fun to try and figure out. |
10th Aug 2023 2:03am |
Philipp1601 Member Since: 17 Feb 2023 Location: Borken Posts: 19 |
Click image to enlarge I a new owner of a IID-Tool BT I bought from ExpeditionParts in Germany. The IID-Tool BT was delivered today, I updated it to 4.00.00 build 3034. The car is brand new, too. It is a 2024 Defender 110 D250 XS. btw: There are some problems with activating the „inControl“ service of the car, the dealer is trying to find out with LR. So the car is not yet activated. It seems this is not the only car that does not activate, the activation procedure was changed, there is a problem with LR. In the meantime I tried to code the CCF file to unlock some features. I started with one of the simpler ones: I tried to activate the wifi hotspot by MultiCAN-814 IVIWiFiHotspot Standard: Not fitted Changed to: Internal WiFi Hotspot fitted When I tried to upload the changes to the car it said: Click image to enlarge „CCF version not yet supported“ and the app fell back to the main menu. Any other CCF-change ends the same. Can one of you help me with the problem? Is anybody else suffering the activation problems with LR? Thank you Philipp Last edited by Philipp1601 on 11th Aug 2023 10:53am. Edited 4 times in total |
10th Aug 2023 6:44am |
Hi Scott,
to understand if you have matrix lights it's very simple, you have to physically look at the front light when you open the bonnet. There is a white label with the code of the lighthouse, look at the absorption watts, this is a matrix label: Click image to enlarge this instead a premium label: Click image to enlarge so if you have matrix headlights, setting the exact ccf everything will work, if you don't have matrix headlights, the adb key will appear on the pivi, but the headlights won't work adaptively. Cheers Marco |
10th Aug 2023 6:55am |
HI, I think Patrick should be heard, (now I'm on vacation until 28/08. ) only thing that comes to mind, are you logged in to get full functionality on the tool on your chassis number? otherwise you have no access to ccf encryption and reduced functionality. Cheers Marco |
10th Aug 2023 7:18am |
Thank you for your reply, Marco,
I already activated the tool and locked it to my car's VIN. So it should work, I think. greetings Philipp |
10th Aug 2023 9:29am |
As Marco has said drop GAP an email
gapteam@gap-diagnostic.com Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
10th Aug 2023 11:53am |
I have tried to collate all the known working settings into this post, if anybody spots a mistake or has an addition to make just shout
---------------------------------------- - Activate WIFI/WLAN Hotspot MultiCAN-814 IVIWiFiHotspot Standard: Not fitted Changed to: Internal WiFi Hotspot fitted ---------------------------------------- - Change Splash Screen to "Defender 007" EUCD-205 Racing Sub Brand Standard: Mainstream Vehicle Changed to: LTD 007 ---------------------------------------- - Dynamic Mode EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted MultiCAN-777 Ter Dyn Select In FCPB Standard: Control interface not available in FCPB Changed to: Rotary used for selection within touch screen ---------------------------------------- -Remember Stop/start setting MultiCAN-566 MHLastUserMode = Enabled ---------------------------------------- For Walk away locking and Approach unlocking the general rule is that it is only available on MY2023 onward, if you don’t have a locking fuel cap you can enable both. You will also have to go into your centre screen setting and switch it on. Some people with earlier cars have got this to work but it is a bit of a lottery -WalkAwayLocking MultiCAN-505 Change it to Current: Enabled ---------------------------------------- -Approach unlocking MultiCAN-807 Approach Unlocking Disabled Change to Enabled ---------------------------------------- -Modify signature LEDs behavior MultiCAN-463 DRLBehWhilstDIsAct Current: Turn Off New: No Action MultiCAN-465 DRLBehWhHazardsAct Current: Turn Off New: No Action This setting is to keep them on while the turn signals or hazard lights are operating. ---------------------------------------- - The subwoofer was installed in the base model, but wasn't enabled. EUCD-121 Subwoofer Standard: Without Subwoofer Changed to: Subwoofer ---------------------------------------- -Enable All Microphones EUCD-126 Microphone = Four Microphones (Two Front & Two Rear) Standard: Microphone (Driver Only) ---------------------------------------- - Disbale Seatbelt Reminder MultiCAN-717 Front Belt Minder Beltminder Fully OFF ---------------------------------------- - MultiCAN-770 Remote Release Tailgate Enabled This will make the rear door pop open when you press the button on the key fob ---------------------------------------- -MultiCAN-723 Gloabal open/close MultiCAN 723 SMRF Global Close - changed to Enabled MulitCAN 719 CDL Global Close - changed to Enabled MultiCAN 719 CDL Global Open - changed to Enabled EUCD 184 Global Open/Close - changed to Global Open/Close Doors + Sunroof ---------------------------------------- - Configurable TR MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout ---------------------------------------- A couple of videos that should help new users How to enable the James Bond Screen How to email a copy of your CCF File to yourself Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
10th Aug 2023 12:06pm |
MickD Member Since: 28 Jul 2023 Location: New England Posts: 28 |
That's great. I wished I had that when I first started. It really should be stickied and not buried on page 40 of a thread.
One thing I don't see in your list is fogs with high beams. I read that this would do it but it didn't work for me. EUCD-018 Foglight Function Foglight without restrictions |
10th Aug 2023 1:11pm |
