![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1440 ![]() ![]() ![]() |
A quick search of the ccf file brings up MultiCAN-784 Front Fog Funtionality Front Fog/SBL/CL Maybe try changing the setting but it may need some trial and error. As for your headlamps can't you just switch auto headlamps off? ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3016 ![]() ![]() |
You can turn them off, but they seem to turn themselves back on again. The only way to stop them turning on and off seems to be, to have them permanently on all the time.
l had one guy in front of me get out of his car asking me why l was flashing my headlights at him. We were in fairly slow moving traffic on a tree lined road. |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 156 ![]() ![]() |
Can you stop the mirrors from auto-folding with the GAP tool so they only work manually with the buttons next to the electric window switches?
When we are towing the caravan l can't lock the vehicle as the towing mirror brackets hit the door when the mirrors fold. |
Vitalka Member Since: 11 Apr 2023 Location: NJ Posts: 3 ![]() ![]() |
Has anyone upgraded their standard LED to Premium LED (non matrix)? What changes in the CCF need to be made? I tried every possible MultiCAN 679 variants and was not able to get the DRLs to work. The headlights work fine
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 174 ![]() ![]() |
HI,
I upgraded from base to matrix, everything works fine, surely the important ccf is 679, even more important is that the headlights must be used, the control units on the headlights must be the original ones of the headlights (in practice the control units must not come from other random headlights) and the headlights must have a specification of your country. Are the drls on the headlights working? aren't they defective? if necessary, write me in Pm. Cheers Marco |
Thanks for your reply. The headlights I bought are used from eBay. What I noticed is when putting the car in drive or reverse sometimes the four square LEDs come on, but not the bottom rings
multican-463,multican-465, multican-468,multican-470, try to look at these, if it doesn't work I think it's a problem of complex headlights and control units. on my car I mounted headlights from Germany, as soon as I installed them the drl worked, before doing the matrix coding.
Changed MultiCan-468 from Incorporated DRL and Pos to Incorporated DRL and DI and now the little squares light up in yellow as DRL
Anyone know how to stop the auto-fold mirrors from folding?
hthagood Member Since: 26 Jun 2023 Location: Texas Posts: 4 ![]() ![]() |
Hey there! New to the group and took the plunge on the tool and so far have added: -007 splash -Auto Stop/Start memory -Dynamic Mode On Dynamic Mode, I was able to get the rotary enabled to select/engage: MultiCAN-777 Ter Dyn Select In FCPB Standard: Control interface not available in FCPB Changed to: Rotary used for selection within touch screen Seems to work well so far...also, I do have the red dials...I have a '23 130-X |
Hello,
thank you very much, today I changed the ccf, perfect, I was very annoyed that I could not vary the mode from the rotary knob. unfortunately for meniente red dials..... ![]() ![]() ![]() Cheers Marco |
Good find hthagood
![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
StromC Member Since: 30 Jan 2023 Location: Rockville Posts: 13 ![]() ![]() |
Messed with this a bit this weekend. I had aftermarket fog lights added on the grill. Installer set up a relay so that the new lights would turn on with the factory fogs. Unfortunately only after did I realize that the fog lights come on with the indicators. So, I was blinding drivers every time I put the signals on. I ended up having to disconnect the added fogs. MultiCAN-784 doesn't seem to impact this. I tried all of the options and it just changes what turns on when you hit the fog light switch. It had no effect on the fog lights turning on with the indicators. Please let me know if anyones has any other ideas. Thanks |
