Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 35 of 104 <123 ... 343536 ... 102103104>
roccobarocco
Germany
I just joined your group and wish to participate in this discussion. Don't have a Defender yet but it's coming. However, we own also a MY23 Discovery D300, so I started fiddling a bit around with Gap IID which works splendidly. I did the Wifi and the key away locking feature. Works nice (-:
Today I tried to unlock the speed limiter from factory setting 209km/h to the new value of 225km/h, it works but it gives me an error that collision warning is not working and the cruise control is without function, anyone has an idea how to mitigate this problem?
Many wishes
roccobarocco
TIA
Post #997785 27th Jun 2023 7:09pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
lightning wrote:
lightning wrote:
Couple of questions from someone who has just got the GAP tool.
1/ can you turn off the fog light illumination when you use the indicators, as l think it's stupid.
2/ Can l stop the headlights from coming on every time l drive under a tree on a dull day? l can disable it with the headlights switch but then it starts doing it again.
Anybody?
A quick search of the ccf file brings up
MultiCAN-784 Front Fog Funtionality
Front Fog/SBL/CL
Maybe try changing the setting but it may need some trial and error.
As for your headlamps can't you just switch auto headlamps off? Confused Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #997815 27th Jun 2023 11:00pm
lightning
You can turn them off, but they seem to turn themselves back on again. The only way to stop them turning on and off seems to be, to have them permanently on all the time.
l had one guy in front of me get out of his car asking me why l was flashing my headlights at him. We were in fairly slow moving traffic on a tree lined road.
Post #997820 28th Jun 2023 6:57am
stevemfr
France
Rolling with laughter
That just made me spew my beer. That's just really funny to imagine. "Why are you flashing me?"
Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #998223 1st Jul 2023 11:20pm
lightning
Can you stop the mirrors from auto-folding with the GAP tool so they only work manually with the buttons next to the electric window switches?
When we are towing the caravan l can't lock the vehicle as the towing mirror brackets hit the door when the mirrors fold.
Post #998688 5th Jul 2023 9:10am
Vitalka
United States
Has anyone upgraded their standard LED to Premium LED (non matrix)? What changes in the CCF need to be made? I tried every possible MultiCAN 679 variants and was not able to get the DRLs to work. The headlights work fine
Post #998715 5th Jul 2023 1:07pm
mmbanf
Italy
HI,
I upgraded from base to matrix, everything works fine, surely the important ccf is 679,
even more important is that the headlights must be used, the control units on the headlights must be the original ones of the headlights (in practice the control units must not come from other random headlights) and the headlights must have a specification of your country.
Are the drls on the headlights working? aren't they defective?
if necessary, write me in Pm.
Marco
Post #998716 5th Jul 2023 1:24pm
Vitalka
United States
Thanks for your reply. The headlights I bought are used from eBay. What I noticed is when putting the car in drive or reverse sometimes the four square LEDs come on, but not the bottom rings
Post #998719 5th Jul 2023 1:37pm
mmbanf
Italy
multican-463,multican-465, multican-468,multican-470, try to look at these, if it doesn't work I think it's a problem of complex headlights and control units. on my car I mounted headlights from Germany, as soon as I installed them the drl worked, before doing the matrix coding.
Post #998722 5th Jul 2023 1:48pm
Vitalka
United States
Changed MultiCan-468 from Incorporated DRL and Pos to Incorporated DRL and DI and now the little squares light up in yellow as DRL Very Happy
Post #998737 5th Jul 2023 4:25pm
lightning
Anyone know how to stop the auto-fold mirrors from folding?
Post #998746 5th Jul 2023 5:18pm
hthagood
United States
Hairy Dan wrote:
That's correct you can't select dynamic with the knob you have to touch the screen Thumbs Up
Hey there! New to the group and took the plunge on the tool and so far have added:
-007 splash
-Auto Stop/Start memory
-Dynamic Mode
On Dynamic Mode, I was able to get the rotary enabled to select/engage:
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
Seems to work well so far...also, I do have the red dials...I have a '23 130-X
Post #999116 7th Jul 2023 8:24pm
mmbanf
Italy
Hello,
thank you very much,
today I changed the ccf, perfect, I was very annoyed that I could not vary the mode from the rotary knob.
unfortunately for meniente red dials..... Big Cry Big Cry Big Cry
Marco
Post #999263 8th Jul 2023 7:47pm
Hairy Dan
Good find hthagood Bow down Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #999274 8th Jul 2023 10:27pm
StromC
United States
Anybody?
Front Fog/SBL/CL
Messed with this a bit this weekend. I had aftermarket fog lights added on the grill. Installer set up a relay so that the new lights would turn on with the factory fogs. Unfortunately only after did I realize that the fog lights come on with the indicators. So, I was blinding drivers every time I put the signals on. I ended up having to disconnect the added fogs.
MultiCAN-784 doesn't seem to impact this. I tried all of the options and it just changes what turns on when you hit the fog light switch. It had no effect on the fog lights turning on with the indicators.
Please let me know if anyones has any other ideas. Thanks
Post #999492 10th Jul 2023 2:21pm
