Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 25 of 109 <123 ... 242526 ... 107108109>
cfitzge
United States
graemesmith1960 wrote:
Has anyone managed to get Tow Assist 2 to work? I've set all as per pervious posts:
I'm just not getting the Wheel icon with a trailer attached nor the red lines. The trailer button between the aircon dials does not work either.
I've got Surround Cameras so that should not be the problem, what I have noticed is that Advanced Tow Assist usually comes with ATPC. Enabling ATPC keeps throwing up the Emergency Brake Assist Warning though.
FWIW I have factory Tow Assist 2, and don’t have the wheel icon, and the button between the air on knobs doesn’t do anything. My assumption is that nothing happens unless you have a trailer attached.
Post #984347 4th Mar 2023 1:53am
graemesmith1960
Even when I attach a trailer it doesn't work.
Back to the drawing board!
Edit:
Not quite - the wheel icon appeared this morning. That's taken it over 36 hours to appear. Unfortunately I can only test it with a lighting board as my trailer is covered up at the moment. I can get the steering option to appear with a Green Tick but the Start button is greyed out and the screen says Reserved. Hopefully when I hook up a real trailer it will work. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #984375 4th Mar 2023 1:13pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I have pretty much the same result as you Graeme, I suspect there is another 'switch' that needs flipping that isn't available to us yet or as I think you mentioned earlier it needs ATPC enabled to work Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #984389 4th Mar 2023 4:57pm
graemesmith1960
Yes, I think you are correct. I haven't had the chance to leave the car for any length of time with ATPC enabled to see if the Emergency Braking fault eventually disappears but I doubt Advanced Tow Assist will work without it. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #984391 4th Mar 2023 5:23pm
tooth_dr
Northern Ireland
I don’t think we are going to get much more out of the gap tool by the sounds of it.
Post #984415 4th Mar 2023 9:49pm
stevemfr
France
Posted one page back in this thread Cool
stevemfr wrote:
We will have to continue working on individual items and updating the fw in the future. We simply don't have the resources to do everything all at once.
Cheers,
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #984516 5th Mar 2023 6:26pm
lightning
Any ideas as to how long before this diagnostic tool will be available to buy for the L663?
l'll take one straight away.
Post #984558 6th Mar 2023 8:48am
stevemfr
France
We will likely release in the coming weeks. Keep an eye on this thread. Thumbs Up
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
Post #984573 6th Mar 2023 10:56am
Hairy Dan
Just had a chance to look through a ccf file downloaded via Pathfinder and it looks like there are a couple of settings in there which a few of us have been looking for, let's just hope they become available when the tool comes out of beta and solve the activations we are working on
MultiCAN754 AutoTRProgMode
MultiCAN755 ConfigTRMode
MultiCAN778 ATPCSelectInFCPB
MultiCAN778 TerAutoSelectInFCPB
MultiCAN801 ATPCPRO
There could be more, these are just some that jumped out at me when I was looking through it and I'm hoping the reading of faults is fixed soon also as I still can't read faults Confused Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #984736 7th Mar 2023 7:53pm
pllr
United States
That's encouraging about the new/different codes from the Pathfinder CCF. Thanks.
Any chance you could scan through it for anything to do with Adaptive Cruise Control? I can't get ACC to activate with the GAP tool in our 2023. I always get an AEB warning.
Post #984815 8th Mar 2023 12:01pm
MattF
United States
From what I understand there is an ECU (for towing) that needs to exists for Advanced Towing to function. Again I may be "mis-remembering" but coding alone wont work.
Maybe looking at a part diagram might help?
Edit:
Post #984889 8th Mar 2023 11:12pm
Nashvegas
United States
Got my IIDTool up and running this past week. As an aside, huge thanks to Patrick for the lightning fast emails... I mean *amazing* customer service.
Futzed around with it on my 2020 110 X. I can't seem to get the last user mode 566 below to work -- but reading here, seems to work for most everyone. Any ideas?
Remember Stop/start setting
MultiCAN-566 MHLastUserMode =
Was = Disabled
Changed to = Enabled
Also I have an Aussie bull bar and winch installed on mine, and I was able to change "631 Lower Active Grille Vanes: from “both upper and lower active vanes” to “upper active vanes only”.... as when you install the winch you have to remove the lower a active grille. Which causes a code. So, problem solved!
Anyway, had lots of fun playing with it.
Post #984955 9th Mar 2023 4:39pm
Hairy Dan
I'm pretty sure if you have the electrically deployable tow bar it is just a matter of coding Cheers Ian
Kielder 4x4 Safari
Post #984961 9th Mar 2023 5:43pm
Hairy Dan
Was = Disabled
Have you let the car go to sleep and rebooted the pivi system afterwards? Cheers Ian
Kielder 4x4 Safari
Post #984962 9th Mar 2023 5:48pm
stevemfr
France
Thanks Ian, was just going to say the same Thumbs Up
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
Post #984980 9th Mar 2023 11:19pm
