Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 73 of 110 <123 ... 727374 ... 108109110>
stevemfr
France
Hi Carl,
Yes, of course. We are well aware that there will be instances such as yours and we aren't a gov't agency bound by law Razz
This was also my reason for the last sentence I wrote above: any questions, etc please just send us an email to support at gap - diagnostic dotcom
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1021829 19th Jan 2024 9:39pm
Chris S
I know it’s a bit brass necked of me, but, I know I could upgrade a G2 to G3 (and was about to) but will there be a G2 to G4 upgrade choice/programme? Or should I sell the G2?
Thanks in advance.
Chris.
Post #1022000 21st Jan 2024 12:02pm
stevemfr
France
Hi Chris,
No, unfortunately we can't offer a G2 upgrade anymore. We do try to take everyone with us as we move up, but at some point it is no longer economically viable. Sorry.
I'd suggest the "For Sale" sections in one of the sister forums to this one catering to older vehicles we cover. As older L322s and D3s become less expensive, their owners often do not want to spend the full price on an IIDTool. Razz
https://www.fullfatrr.com/forum/for-sale-wanted-vf11.html
http://www.disco3.co.uk/forum/fs-parts-accessories-vf85.html
There are 2 at disco3 that recently sold for £325 plus postage. So that really seems like the best way forward.
If only LRs held their value that well... Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
Post #1022040 21st Jan 2024 3:51pm
Chris S
No problem at all, I know I was chancing it a bit Laughing
I will put on the market, it is like new it should go no problem. MY24 X-Dynamic HSE D250 110, Santorinis Black, Matrix LED headlights, Dark grey cross car beam, Air suspension, HUD, Secure Tracker pro, Wheel arch protection, Deployable tow bar.
Post #1022042 21st Jan 2024 4:12pm
northeye
Japan
Hello.
I've found new activations after upgrading firmware to B3906.
Soft Buttons on sidebar interface. (see hunters "DEFENDER PIVI PRO MY25 INTERFACE" activation)
    * MultiCAN-882 Sidebar Controls
    from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i"
    * MultiCAN-892 SideBar Climate
    from "Climate Icon on Side Bar Not Available" to "Climate Icon on SIde Bar Available - FICP Replacement"
    * MultiCAN-896 ReCircle Soft Button
    from "Not Fitted" to "Soft Button Fitted with timed and latched logic"
    * MultiCAN-897 Max AC Soft Button
    from "Not Fitted" to "Soft Button Fitted"
    * MultiCAN-897 Max Defrost Soft Button
    * MultiCAN-897 AC OnOff Soft Button
    * MultiCAN-897 Auto Climate Soft Button
    from "Front AUTO Climate Soft Button Not Fitted" to "Front AUTO Climate Soft Button Fitted"
    * MultiCAN-898 Front Htd Screen Soft Button
    * MultiCAN-898 Rear Htd Screen Soft Button
    * MultiCAN-894 Volume Soft Keys
    from "Not Fitted" to "Audio Volume Soft Keys pattern 1"
Volume button has been appeared on sidebar but unfortunately it does not work correctly for me.
Shortcut panel of Home screen is contained with this activation, maybe.
Deep Clean app
    * MultiCAN-872 Cabin Cleaning
    from "Not Fitted" to "Variant B Fitted - Off-Board On Demand activation + Scheduled activation both On and Off Board"
    * MultiCAN-878 PN Cabin Cleaning
    from "PN Cabin Cleaning Disabled" to "PN Cabin Cleaning Enabled"
I've also found the "SV Bespoke" startup Logo but not worked Sad
    * MultiCAN-890 Startup Logo
    from "Not Supported" to "SV Vehicle Personalisation Bespoke"
Additionally, some SV mode settings are available but it seems no effect on my vehicle.
    MultiCAN-875 SV Dynamic Mode
    MultiCAN-887 SV Shift Light Amber
    MultiCAN-888 SV Shift Light Red
    MultiCAN-889 SV Shift Light Red Flash
    MultiCAN-891 SV Shiftight Hysteres
    MultiCAN-903 SV Dynamic Mode Ride Height
    MultiCAN-903 SV Roof Load Advice
Thanks.
DEFENDER 110X D300 / from JAPAN.
Post #1025268 20th Feb 2024 8:55am
Ratledge
United States 2016 Defender 90 300 Tdi SW Auto Stornoway Grey
You can already order a 2025 ("MY25") in Japan?
Post #1025377 20th Feb 2024 9:43pm
northeye
Japan
No. My vehicle is MY23.5
Even if it's 23, activation is still possible. The requirement is PIVI Pro version 4.0 or above, I believe.
Post #1025395 21st Feb 2024 12:07am
vincel
United States
On a US Spec 2021 110 P400 I tried this and while it accepted the change, the auto stop will not remember last setting. Any other ideas?
-Remember Stop/start setting
MultiCAN-566 MHLastUserMode = Enabled
Also, Another thing I noticed programming Dynamic Mode:
The process I followed said to do the following:
- Dynamic Mode
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
Looking at a post also in this forum, they had the above steps PLUS the following change:
MultiCAN-682 DynamicLiteMode Set to Available for Selection Without Timeout.
Anyone know what this additional step does?
Post #1025398 21st Feb 2024 2:21am
lightning
The stop/start last user mode memory seems to be hit and miss, some find that it works (it did on my 2022) and others find that it doesn't work.
Post #1025409 21st Feb 2024 8:50am
DefenderMidlands
I think this setting allows you to select dynamic Mode from the touchscreen OR the rotary control MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1025410 21st Feb 2024 8:53am
Retroanaconda
I did the stop/start thing on mine the other day, it takes a few ignition cycles and pivi resets to take effect but now works perfectly.
Post #1025425 21st Feb 2024 10:08am
carltb
 2015 Defender 110 Puma 2.4 DCPU Corris Grey
Does anyone know which setting to change to set the "CONFIGURABLE DRIVERS ASSIST ( MY24 ONLY)" to last user? 2025 Defender 130 V8 (DOA, new one coming)
2025 Defender 90 D250 (wifes)
2024 Defender 110 p400e HSE (sold)
2015 Defender 110 Double cab
2004 Defender 90 Td5
Post #1025534 21st Feb 2024 8:41pm
Ratledge
Gap iid tool "Gen 4" upgrade on order...
I don't think this is shipping? Hairy Dan?
Post #1025664 23rd Feb 2024 12:33am
pjeski
United States
(Snip)
Post #1025667 23rd Feb 2024 1:14am
OHRT
United States
Edit:
removed links.
Post #1025760 23rd Feb 2024 8:19pm
