![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Chris S Member Since: 22 May 2023 Location: Aberdeenshire Posts: 43 ![]() ![]() |
I know it’s a bit brass necked of me, but, I know I could upgrade a G2 to G3 (and was about to) but will there be a G2 to G4 upgrade choice/programme? Or should I sell the G2?
Thanks in advance. Chris. |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 148 ![]() ![]() |
Hi Chris,
No, unfortunately we can't offer a G2 upgrade anymore. We do try to take everyone with us as we move up, but at some point it is no longer economically viable. Sorry. I'd suggest the "For Sale" sections in one of the sister forums to this one catering to older vehicles we cover. As older L322s and D3s become less expensive, their owners often do not want to spend the full price on an IIDTool. ![]() https://www.fullfatrr.com/forum/for-sale-wanted-vf11.html http://www.disco3.co.uk/forum/fs-parts-accessories-vf85.html There are 2 at disco3 that recently sold for £325 plus postage. So that really seems like the best way forward. If only LRs held their value that well... ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
No problem at all, I know I was chancing it a bit
![]() I will put on the market, it is like new it should go no problem. MY24 X-Dynamic HSE D250 110, Santorinis Black, Matrix LED headlights, Dark grey cross car beam, Air suspension, HUD, Secure Tracker pro, Wheel arch protection, Deployable tow bar. |
northeye Member Since: 18 Sep 2022 Location: Tokyo Posts: 17 ![]() ![]() |
Hello.
I've found new activations after upgrading firmware to B3906. Soft Buttons on sidebar interface. (see hunters "DEFENDER PIVI PRO MY25 INTERFACE" activation)
from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i" * MultiCAN-892 SideBar Climate from "Climate Icon on Side Bar Not Available" to "Climate Icon on SIde Bar Available - FICP Replacement" * MultiCAN-896 ReCircle Soft Button from "Not Fitted" to "Soft Button Fitted with timed and latched logic" * MultiCAN-897 Max AC Soft Button from "Not Fitted" to "Soft Button Fitted" * MultiCAN-897 Max Defrost Soft Button from "Not Fitted" to "Soft Button Fitted" * MultiCAN-897 AC OnOff Soft Button from "Not Fitted" to "Soft Button Fitted" * MultiCAN-897 Auto Climate Soft Button from "Front AUTO Climate Soft Button Not Fitted" to "Front AUTO Climate Soft Button Fitted" * MultiCAN-898 Front Htd Screen Soft Button from "Not Fitted" to "Soft Button Fitted" * MultiCAN-898 Rear Htd Screen Soft Button from "Not Fitted" to "Soft Button Fitted" * MultiCAN-894 Volume Soft Keys from "Not Fitted" to "Audio Volume Soft Keys pattern 1" Volume button has been appeared on sidebar but unfortunately it does not work correctly for me. Shortcut panel of Home screen is contained with this activation, maybe. Deep Clean app
from "Not Fitted" to "Variant B Fitted - Off-Board On Demand activation + Scheduled activation both On and Off Board" * MultiCAN-878 PN Cabin Cleaning from "PN Cabin Cleaning Disabled" to "PN Cabin Cleaning Enabled" I've also found the "SV Bespoke" startup Logo but not worked ![]()
from "Not Supported" to "SV Vehicle Personalisation Bespoke" Additionally, some SV mode settings are available but it seems no effect on my vehicle.
MultiCAN-887 SV Shift Light Amber MultiCAN-888 SV Shift Light Red MultiCAN-889 SV Shift Light Red Flash MultiCAN-891 SV Shiftight Hysteres MultiCAN-903 SV Dynamic Mode Ride Height MultiCAN-903 SV Roof Load Advice Thanks. DEFENDER 110X D300 / from JAPAN. |
Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28 ![]() ![]() ![]() |
You can already order a 2025 ("MY25") in Japan?
No. My vehicle is MY23.5
Even if it's 23, activation is still possible. The requirement is PIVI Pro version 4.0 or above, I believe. |
vincel Member Since: 19 Feb 2024 Location: NYS Posts: 6 ![]() ![]() |
On a US Spec 2021 110 P400 I tried this and while it accepted the change, the auto stop will not remember last setting. Any other ideas?
-Remember Stop/start setting MultiCAN-566 MHLastUserMode = Enabled Also, Another thing I noticed programming Dynamic Mode: The process I followed said to do the following: - Dynamic Mode EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted MultiCAN-777 Ter Dyn Select In FCPB Standard: Control interface not available in FCPB Changed to: Rotary used for selection within touch screen Looking at a post also in this forum, they had the above steps PLUS the following change: MultiCAN-682 DynamicLiteMode Set to Available for Selection Without Timeout. Anyone know what this additional step does? |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2943 ![]() ![]() |
The stop/start last user mode memory seems to be hit and miss, some find that it works (it did on my 2022) and others find that it doesn't work.
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 241 ![]() ![]() |
I think this setting allows you to select dynamic Mode from the touchscreen OR the rotary control MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
I did the stop/start thing on mine the other day, it takes a few ignition cycles and pivi resets to take effect but now works perfectly.
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 63 ![]() ![]() ![]() |
Does anyone know which setting to change to set the "CONFIGURABLE DRIVERS ASSIST ( MY24 ONLY)" to last user? 2025 Defender 130 V8 (DOA, new one coming)
2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
Gap iid tool "Gen 4" upgrade on order...
I don't think this is shipping? Hairy Dan? |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 109 ![]() ![]() |
(Snip)
OHRT Member Since: 21 Sep 2023 Location: Ohio Posts: 2 ![]() ![]() |
Edit:
removed links. Last edited by OHRT on 23rd Feb 2024 8:03pm. Edited 1 time in total |
