![]() | Home > Maintenance & Modifications > New swivel housing ball needed. |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2158 ![]() ![]() ![]() |
Your swivels will soon be as clean as these 👍
Screbbie is showing off now. That's pornographic pic right there. I'd frame it. Clearly hasn't see the winter gritters evil salt yet. Lovely though. Ahhhh them wer the days.
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
There's your problem. Find a decent indy ![]() OEM swivel kit is under £200. Few hours labour, job done ![]() |
Buttons Member Since: 24 Nov 2018 Location: Galway Posts: 34 ![]() ![]() |
I'm only a newish newby so go easy. I may be completely wrong.
I would think there is a possibility the drive shaft oil seals may have been damaged during the recent work allowing diff oil into the housing or pressure to build up if the breather is blocked? Just a suggestion, and to keep in mind replacing the swivels may not fix the problem if the oil seals have been damaged with diff oil leaking to the swivel. A good sniff required? Sorry, new to landrovers, rebuilding a 110 from the crankshaft up, but this seems too much of a coincidence. |
Good point about the oil seal. Definitely worth looking into.
The axle/driveshaft oil seal sits in the rear of the swivel ball so it would be replaced as part of that replacement process (one would hope!) ![]() PS make sure you install it the correct way round. |
For the avoidance of doubt…
My reference to fitting the correct way round was in relation to the oil seal not the swivel ![]() ![]() Click image to enlarge |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5929 ![]() ![]() ![]() |
Greaseable TRE's. - Available as off the shelf items? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Exo. Yes. Gwyn Lewis.
cheers 1999 Defender TD5 110
As Keith says - yes available from Gwyn Lewis in a number of options. Go for the poly boot if you are going to purchase. Other manufacturers and suppliers available of course but you can’t go wrong with GL ![]() |
ksv Member Since: 04 Nov 2014 Location: Volgograd Posts: 19 ![]() ![]() ![]() |
Hi all
Mine was curd by the halfshaft seal replacement. |
Was cured... Sorry
