Home > Puma (Tdci) > Bonnet stolen again. |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
When mine was stolen the CITV shows the persons overriding the alarm at 23.40 about 2mins of a person lurking arround the vehicle, the 02.20 am large Merc van pulls up 2men 18 secs big crowbar staight into the slam panel gap piece of metal to protect the bonnet edge force the lock bonnt up to near vertical and 2 men straight off into the van gone seamless.
I know someone has tryed to have another go a couple of monts ago but this time the alarm went off due to my overides fitted listed here and my cycle lock cable also listed here. I am having an idea using hotel window opening restraints as they are strong and secure, i got a load for my home to stop the ground floor windows being forced and to stop the dog getting out if the windows were left open. Quick secure simple i hope going to do some tests this weekend idea will be free to every one on here. If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
20th Sep 2011 9:56pm |
With a little more thought this could have been an excellent piece of kit....and the manufacturers could have been onto an absolute 'cash cow!' I'll say it like it is.....To me it looks !...Lesser of two evils, I suppose it depends on how vulnerable you consider your bonnet to be to theft whether you fit this piece of Meccano! For me personally it needs to look aesthetically pleasing too! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
21st Sep 2011 9:39am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17475 |
If you visit the manufacturer's website you will see that the Motorhaubenscharniere is designed to be used with their Halter für Wagenheber, and when the two items are combined the Scharniere makes a lot more sense - it is not designed as an anti-theft device. It definitely looks better in the black. If you were to put your Wagenheber in the Halter, it might slow down the bonnet thief. Alternatively I guess you would lose your Wagenheber and your expensive Scharniere and Halter as well as the bonnet! There are however some neat products on their website - I rather like the Gasdruckfedern concept, but I am not so keen on the Kotflügelbleche that is required with this. The top brackets for the Gasdruckfedern look neat, and this idea might be capable of development into an antitheft solution. The Staubox Kotflügel might have security uses too. Interesting, food for thought. |
21st Sep 2011 11:19am |
^^^ I didn't understand much of that BW, it's lunchtime and I think my sugar levels must be low Steve.
21st Sep 2011 11:56am |
For readers with low sugar levels!
21st Sep 2011 12:07pm |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
What about fitting an old style bonnet support. If that was riveted surely it would stop the bonnet going vertical and would be (fairly) hard to remove?
21st Sep 2011 12:08pm |
Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
21st Sep 2011 12:41pm |
Gil9713 Member Since: 11 Sep 2011 Location: Colchester Posts: 94 |
Here are the photos of the conversion today which took 30 minutes hope its helpful to members using the bolts and nuts as mentioned earlier.
Gil Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us |
22nd Sep 2011 6:01pm |
Using 8" made up battery wire £5 and shrink wrapped at either end with correct looped end to accept the M6 bolts on the chassis and the bonnet, one screw used on the outer hinge with anti tamper nut underside.
A 10" steel clothes rod used with shrink wrap at either end to prevent rattling on front panel compartment fitted over bonnet release wire thereby preventing access to cut the wire. Pic 1 N/S Pic 2 O/S Pic 3 Steel pole shrink wrapped either end fitted over bonnet release wire Pic 4 Ditto Pic 5 Showing 8 " battery straps Pic 6 Showing one anti tamper screw head bonnet side Pic 7 Label on front end This would take some time now to be able to remove this bonnet now, but it is purely a delaying tactic as with ALL motor thefts and the devices employed. I have also got the clear backed labels in white lettering on the drivers glass without white backing. Gil |
22nd Sep 2011 6:09pm |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 |
Gil9713 where did you get the stickers made up? Mermoto |
22nd Sep 2011 6:52pm |
I have the technology and probably get a slap on the wrist from LR for making my own, but they should have tackled the bonnet problem in house and come up with easy cost effective update a long time ago.
22nd Sep 2011 7:53pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Like this? Click image to enlarge I wondered the same before, but as someone said on here they could be pretty lethal if you were working under the bonnet and knocked it, or the wind blew it shut... Having said that if you could 'lock' it open I don't think it'd be as bad... apart from possibly getting in the way |
22nd Sep 2011 11:50pm |
It worked all right for the last lot of defenders Maybe even make it so you can use the old / new the only reason its there is to stop bonnet going vertical. |
23rd Sep 2011 5:29am |
Yep, I've had them come down on me with and without a spare wheel mounted on them. Technically speaking even those supports are just held onto the bracket with a small split-pin and washer - 15 seconds with a pair of pliers and they're off. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
23rd Sep 2011 6:08am |
