Home > Puma (Tdci) > who does and who doesn't use 1st gear? |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
6th is best, with lots of slip
17th Mar 2012 7:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20334 |
What 0 - 60mph in 30 minutes? |
17th Mar 2012 8:01pm |
Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236 |
I hardly use first always second to pull away I just lift off the clutch and hold it till it reaches a steady speed then lift off then accelerate. I even pulled away at a traffic light in third once in the same way 2012 Fuji White 110 Flattened
17th Mar 2012 8:48pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Always 1st to get rolling, but frequently go from 4th to 6th. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
17th Mar 2012 9:37pm |
Unladen, on the flat and downhill, especially in heavy moving traffic (and if I'm too lazy) I often pull gently away in 2nd - doesn't seem to be much more clutch slip than in 1st However, if I want to get away faster or with any load at all (including even the dogs), 1st every time. Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
18th Mar 2012 6:38am |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 |
They don't, it is a standard 82 gearbox from Ford Transit. Never forget: cars have owner, Landrover have field service personnel. |
18th Mar 2012 12:58pm |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 227 |
Same here, unladen and flat or downhill (very rare around here ) I also drive off in 2nd gear from time to time.
No need to ride the clutch, 2nd on the Puma is not that much different from 1st gear on my Td5. Peter, Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
18th Mar 2012 2:01pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
me wonders what got this thread going again after 2 years?
18th Mar 2012 3:14pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Kona being VERY enthusiastic
18th Mar 2012 3:28pm |
It was indeed me Never saw the post two years ago. |
18th Mar 2012 3:54pm |
I can't even remember what happened yesterday - keeps everything fresh and exciting Tell someone you love them today because life is short.
18th Mar 2012 5:53pm |
That's probably because yesterday was much the same as today |
18th Mar 2012 6:14pm |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
1st all the time pulling away from a stand still. 2nd isn't low enough.
Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
18th Mar 2012 8:50pm |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 |
Tried this today. Can see the point if you need a (relatively) nippy get away across a junction, but doing it regularly must put some extra strain on things. Think I'll stick to the current 1st , accelerate , pause , wait for it , 2nd , off we go again.
Stu |
18th Mar 2012 10:15pm |
