Home > Maintenance & Modifications > Series look light surrounds |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 266 |
I’ve got these in satin on mine. Never seen them without the little grilles between the indicator and sidelight though.
https://www.defender2.net/gallery/albums/u...1C26D.jpeg 2011 130 Utility Body 2005 110 Van |
2nd Feb 2021 10:39am |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 |
Actually they look really good - you mind my asking where you got them? I was thinking if I can’t get an exact match for the mesh I do chose it would maybe be better just blank but I’m open to other good solutions like yours!
2nd Feb 2021 11:23am |
They are from uproar 4x4.
Search this on EBay Land Rover Defender Stealth Metal Headlight Surrounds - Uproar 4x4 2011 130 Utility Body 2005 110 Van |
2nd Feb 2021 11:56am |
I've no idea why these things are so expensive but there's a similar option at a similar price here:
https://www.4x4overlander.com/product/heri...nds-gills/ Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
2nd Feb 2021 12:08pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
I much prefer the look of the above Nakatanenga Heritage Headlight Surrounds with Gills, but they're sill money for what they are. Also note they have a textured finish, so NOT smooth like the Series light surrounds. Puts me off a little too. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
2nd Feb 2021 12:14pm |
I've seen both of these now you've both included the links but think I must have skipped past because of the price! The region of £200?
Thanks chaps will keep them both in mind as the search continues for a more *cough* affordable solution! |
2nd Feb 2021 12:16pm |
I might be able to help there
https://www.defender2.net/forum/post738660.html#738660 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
2nd Feb 2021 12:25pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2304 |
I went for the Nakatanenga heritage ones from 4x4 Overlander as I liked the OEM style horn louvres.
Don't remember them being that price though! They are supplied textured but paint up fine with high build primer. A picture with a zunsport grille too as you mention wanting one of them too Click image to enlarge > 110 XS Double Cab |
2nd Feb 2021 12:29pm |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 |
Just to give you an idea on the look Nananatenga in black on mine; like Hank, I'm sure they were a lot cheaper when I bought them, I suspect Brexit tariff?
Click image to enlarge Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
2nd Feb 2021 12:35pm |
I looked at them last year and they've been around that price for along time. Darren
2nd Feb 2021 1:22pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 |
I have had the Nakatanenga surrounds & finishers on mine since 2014 but they came in a smooth finish which has stood the test of time.
The Nakatanenga grille however is a different matter, that has been on since 2010 and came in a textured finish which started falling off almost straight away. I repainted it once and it was a right royal pain to do. Where the paint had fallen off it cleaned up to bare alloy a treat but where the paint was still present it just would not shift so eventually I settled for a combination of etch & high-build primer which seemed to do the trick. Click image to enlarge ONE LIFE, GET IT! |
2nd Feb 2021 2:55pm |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 |
I am also keen on these but wanted to know if they are a straight swap with original surrounds or do additional holes need to be drilled? |
2nd Feb 2021 5:00pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3431 |
I really wonder if anyone has simply taken a standard finisher, such as BTR7850PUC which are dirty cheap and modified it to look like a series 3 headlamp surround. I have a few spare of those, and would not mind trying out one myself either on a wood table saw, with a fine tooth blade, or a router. Unfortunately I do not have the dimensions for the Series 3 surround. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
2nd Feb 2021 5:34pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
I've had mine on for 6 months or so and its been fine, I think they have improved the paint finish by the sounds of it. I'm going to add the trims Defender Upgrades sell as the price is a lot more palatable. |
2nd Feb 2021 7:07pm |
