![]() | Home > Maintenance & Modifications > Series look light surrounds |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 278 ![]() ![]() ![]() |
I’ve got these in satin on mine. Never seen them without the little grilles between the indicator and sidelight though.
https://www.defender2.net/gallery/albums/u...1C26D.jpeg 2011 130 Utility Body 2005 110 Van |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 ![]() ![]() ![]() |
Actually they look really good - you mind my asking where you got them? I was thinking if I can’t get an exact match for the mesh I do chose it would maybe be better just blank but I’m open to other good solutions like yours!
They are from uproar 4x4.
Search this on EBay Land Rover Defender Stealth Metal Headlight Surrounds - Uproar 4x4 2011 130 Utility Body 2005 110 Van |
I've no idea why these things are so expensive but there's a similar option at a similar price here:
https://www.4x4overlander.com/product/heri...nds-gills/ Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
I much prefer the look of the above Nakatanenga Heritage Headlight Surrounds with Gills, but they're sill money for what they are. Also note they have a textured finish, so NOT smooth like the Series light surrounds. Puts me off a little too. James
I've seen both of these now you've both included the links but think I must have skipped past because of the price! The region of £200?
![]() Thanks chaps will keep them both in mind as the search continues for a more *cough* affordable solution! |
I might be able to help there
![]() https://www.defender2.net/forum/post738660.html#738660 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2315 ![]() ![]() ![]() |
I went for the Nakatanenga heritage ones from 4x4 Overlander as I liked the OEM style horn louvres.
Don't remember them being that price though! They are supplied textured but paint up fine with high build primer. A picture with a zunsport grille too as you mention wanting one of them too ![]() Click image to enlarge > 110 XS Double Cab |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
Just to give you an idea on the look Nananatenga in black on mine; like Hank, I'm sure they were a lot cheaper when I bought them, I suspect Brexit tariff?
![]() Click image to enlarge Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
I looked at them last year and they've been around that price for along time. Darren
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
I have had the Nakatanenga surrounds & finishers on mine since 2014 but they came in a smooth finish which has stood the test of time.
The Nakatanenga grille however is a different matter, that has been on since 2010 and came in a textured finish which started falling off almost straight away. I repainted it once and it was a right royal pain to do. Where the paint had fallen off it cleaned up to bare alloy a treat but where the paint was still present it just would not shift so eventually I settled for a combination of etch & high-build primer which seemed to do the trick. ![]() Click image to enlarge ONE LIFE, GET IT! |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 ![]() ![]() |
I am also keen on these but wanted to know if they are a straight swap with original surrounds or do additional holes need to be drilled? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3477 ![]() ![]() ![]() |
I really wonder if anyone has simply taken a standard finisher, such as BTR7850PUC which are dirty cheap and modified it to look like a series 3 headlamp surround. I have a few spare of those, and would not mind trying out one myself either on a wood table saw, with a fine tooth blade, or a router. Unfortunately I do not have the dimensions for the Series 3 surround. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I've had mine on for 6 months or so and its been fine, I think they have improved the paint finish by the sounds of it. I'm going to add the trims Defender Upgrades sell as the price is a lot more palatable. |
