Home > Maintenance & Modifications > Series look light surrounds
Page 1 of 3 123>
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
I'm going to fit a Mesh style front grille(I'm favouring the Zunsport offering at the moment) in the near future - to complement this I'd like to fit some light surround in the style of Series III vehicles.
Seen a couple of different options but nothing is ideal. Most seem to be offered in Santorini glossy black or body coloured - I want a Matte/Satin black finish and no gap (between the side light and indicator) I'm bound to have overlooked something - can anyone point me in the right direction? Or if what I'm after doesn't exist off the shelf, what would I need to make my own?
*May I add that I'm not intending this to be a authentic concourse standard reproduction - just want to try and nod in the older style's direction.
Post #882556 2nd Feb 2021 10:07am
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I’ve got these in satin on mine. Never seen them without the little grilles between the indicator and sidelight though.
https://www.defender2.net/gallery/albums/u...1C26D.jpeg 2011 130 Utility Body
2005 110 Van
Post #882570 2nd Feb 2021 10:39am
MussEd
Actually they look really good - you mind my asking where you got them? I was thinking if I can’t get an exact match for the mesh I do chose it would maybe be better just blank but I’m open to other good solutions like yours!
Post #882588 2nd Feb 2021 11:23am
mwestcrew
They are from uproar 4x4.
Search this on EBay
Land Rover Defender Stealth Metal Headlight Surrounds - Uproar 4x4 2011 130 Utility Body
2005 110 Van
Post #882597 2nd Feb 2021 11:56am
I've no idea why these things are so expensive but there's a similar option at a similar price here:
https://www.4x4overlander.com/product/heri...nds-gills/ Darren
Post #882604 2nd Feb 2021 12:08pm
JOW240725
I much prefer the look of the above Nakatanenga Heritage Headlight Surrounds with Gills, but they're sill money for what they are. Also note they have a textured finish, so NOT smooth like the Series light surrounds. Puts me off a little too. James
Instagram @suffolk_rovers
Post #882606 2nd Feb 2021 12:14pm
MussEd
I've seen both of these now you've both included the links but think I must have skipped past because of the price! The region of £200? Big Cry
Thanks chaps will keep them both in mind as the search continues for a more *cough* affordable solution!
Post #882607 2nd Feb 2021 12:16pm
I might be able to help there Whistle
https://www.defender2.net/forum/post738660.html#738660 Darren
Post #882611 2nd Feb 2021 12:25pm
hank
I went for the Nakatanenga heritage ones from 4x4 Overlander as I liked the OEM style horn louvres.
Don't remember them being that price though! They are supplied textured but paint up fine with high build primer.
A picture with a zunsport grille too as you mention wanting one of them too
 > 110 XS Double Cab
Post #882613 2nd Feb 2021 12:29pm
Fat Cog
Just to give you an idea on the look Nananatenga in black on mine; like Hank, I'm sure they were a lot cheaper when I bought them, I suspect Brexit tariff?
 Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #882615 2nd Feb 2021 12:35pm
I looked at them last year and they've been around that price for along time. Darren
Post #882627 2nd Feb 2021 1:22pm
Litch
I have had the Nakatanenga surrounds & finishers on mine since 2014 but they came in a smooth finish which has stood the test of time.
The Nakatanenga grille however is a different matter, that has been on since 2010 and came in a textured finish which started falling off almost straight away. I repainted it once and it was a right royal pain to do. Where the paint had fallen off it cleaned up to bare alloy a treat but where the paint was still present it just would not shift so eventually I settled for a combination of etch & high-build primer which seemed to do the trick.
 ONE LIFE, GET IT!
Post #882649 2nd Feb 2021 2:55pm
stephan123
I am also keen on these but wanted to know if they are a straight swap with original surrounds or do additional holes need to be drilled?
Post #882702 2nd Feb 2021 5:00pm
Dinnu
I really wonder if anyone has simply taken a standard finisher, such as BTR7850PUC which are dirty cheap and modified it to look like a series 3 headlamp surround. I have a few spare of those, and would not mind trying out one myself either on a wood table saw, with a fine tooth blade, or a router. Unfortunately I do not have the dimensions for the Series 3 surround. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #882719 2nd Feb 2021 5:34pm
kenzle8a
I've had mine on for 6 months or so and its been fine, I think they have improved the paint finish by the sounds of it.
I'm going to add the trims Defender Upgrades sell as the price is a lot more palatable.
Post #882741 2nd Feb 2021 7:07pm
Page 1 of 3 123>
