Home > My Defender > a 130 itch |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3374 |
Looking 👍
20th Feb 2021 1:48pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
Shame you didn't get an extended rack over the bonnet, looks a bit short!
Looks great!! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
20th Feb 2021 3:08pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8084 |
Its taken a while but after fitting rack a while back the roof tent is now on, plus the skylight! - ( perspex to stop raining coming between tent/awning) i have even managed to sort the wiring for the solar and roof tent light with bulkhead fittings and a connector for when the roof tent is removed. that for me is good going - even more so as they work as intended!
Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
10th Mar 2021 9:02pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Looking great , that really is a vast roof rack !
My 130 arrives on Friday (gales allowing) . I’ll be in touch with Patriot as soon as it arrives . I’ll be selling the double cab as soon as I’ve stripped it of all the upgrades as I can’t believe someone would pay for them on top of what the trucks worth https://www.instagram.com/hustynminepark/ |
10th Mar 2021 9:29pm |
Rack was a special order, with rear legs width centres specified to fit a table inbetween from Patriot. Cheers
11th Mar 2021 9:12pm |
I suppose I should get a black rooftent
Click image to enlarge ..... Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
24th Mar 2021 9:13pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 661 |
Or some black paint 😉😉
24th Mar 2021 9:21pm |
or zome zebra stripes
24th Mar 2021 9:24pm |
Or white rims!! James
24th Mar 2021 9:59pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Just some black vinyl. Easy to do yourself for little money?
25th Mar 2021 6:27am |
theres an idea! maybe i will just take it off! Update on the shower system. i bought a larger heat exchanger this time (than the one in my 110) hoping it would work off engine warm up from cold on tickover. It sort of does but takes away too much heat from the engine - typical! 110 one is plumbed in straight after a webasto coolant heater. think its time to add a webasto coolant heater to the 130. anyone ordered one from Russia....? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Mar 2021 9:59am |
Busy last two days
Changed the vcv, what a horrible job, cured the rough starting and idle but only ran for 20s then stopped. Restarted straight away, first flick, and stopped after 20s again. Removed new vcv, (denso), fitted a 2nd new one (pj jones) and works a treat. Also fitted a webasto evo 5 water heater. Just under £600 new with full fitting kit. Took 5 days from russia. No air intake filter or exhaust silencer but otherwise complete. Slight hiccup with red and black wire needing a home, see other thread, but otherwise now fitted with direct feed to shower heat exchanger before it circulates rest of engine. No more cold starts and no idling to have a hot shower now! Dropped the tank in the end to fit the pickup into top of tank. Not convinced o space on a hicap around the filler. Click image to enlarge Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Apr 2021 3:44pm |
typical, another camping weekend coming up and whats it going to do - RAIN and blow like anything. Cheers
20th May 2021 7:54pm |
Well we got a bit wet but it was worth it. Nice time of year to be out normally!
Click image to enlarge found an interesting tree....s Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th May 2021 7:37pm |
