Home > Puma (Tdci) > MAF and MAP Sensor replacement.
Page 5 of 6 <123456>
Willfindlay
England 2009 Defender 90 Puma 2.4 PU Arles Blue
My 2.4 had started holding the revs for a second or two when going to change gear, I have ordered a new maf and map sensor. Is this likely to be my problem. Thanks
Post #905992 1st Jun 2021 4:25pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Probably not - usual suspect for that is the switch on the clutch master cylinder. Rgds.
Chris
Post #906002 1st Jun 2021 5:40pm
Willfindlay
Great, I’ll get one of them ordered to. Thanks
Post #906010 1st Jun 2021 6:45pm
orzowei
Italy 2008 Defender 90 Puma 2.4 SW Bonatti Grey
quoto pacha e' probabilmente lo switch frizione. a me lo faceva prima di sostituirlo.
Post #915862 6th Aug 2021 8:59pm
orzowei
Post #915863 6th Aug 2021 9:03pm
Sì che è corretto. Darren
Post #915878 7th Aug 2021 5:10am
orzowei
Grazie!!
Post #916410 10th Aug 2021 7:51pm
MartinK
Just cleaned my MAP this morning, it was covered in muck. Engine runs a lot sweeter now, and some of hesitation seems to have gone.
I replaced the VCV, cleaned the MAF (and ordered a new one from Opie Oils which has not arrived yet)
However, the MAP seems to have seriously jumped in price for a genuine Bosch 0261230131 article, looking at over £50!!! Has anyone found a good reputable supplier at a decent cost?
Altho the cleaning seems to have helped, I would like a spare on the shelf Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #922464 23rd Sep 2021 12:25pm
Minch90
OMG if you think the MAP is expensive now, try the MAF at almost £100! 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #934650 22nd Dec 2021 11:05am
Polarismd
Sensors
Hi,
I found these guys on the web. https://www.autodoc.co.uk/
I put my reg in and then searched for the part numbers on Page 1 of this thread.
Apparently these fit 2007 - PUMA.
Any comments?
Chris
Post #964074 5th Sep 2022 12:28pm
Bluest
Auto doc have a bit of mixed reputation shall we say when it comes to delivery times and warranty returns. I would only use them as a last resort. 2007 110 TDCi Station Wagon XS
Post #964102 5th Sep 2022 4:51pm
Pacha
I stuck to more known makes TBH. I have had no real issues with Autodoc providing it is an OEM part. Rgds.
Chris
Post #964111 5th Sep 2022 6:19pm
I’ve used Autodoc, no problems but the delivery took rather a while.
The MAP I’d recommend sticking to a Bosch part, the MAF you’d need to find a Ford parts dealer as the source I originally suggested I believe no longer exists. $W33T $0U7H3RN $UG4R
Post #964114 5th Sep 2022 6:53pm
Polarismd
Hi,
For £70 I will give it a go and give feedback? Or do you advise otherwise.
For the Bosch part I was quoted £245 from LR.
Chris
Post #964136 6th Sep 2022 7:14am
Polarismd
Hi,
For some reason only known to my stupidity I didn't even look on LRCentre or other parts places.
I sort of assumed that these would be special sensors (and difficult to get). I constantly amaze myself how much of a dumbass I can be sometimes.
Both parts are available at LRCentre with whom I have no affiliation (other parts places are available) at a reasonable cost.
Why did LR want to charge so much, do I have "sucker" written on my forehead? - my wife is nodding.
Chris
Post #964137 6th Sep 2022 7:39am
