Home > Puma (Tdci) > Engine knocking? hydraulic lifters??
Page 4 of 6 <123456>
spudfan
Ireland
MK wrote:
Thumbs Up So how did they reckon the fault? bench test?
I suggest you do a good clean up of all your fuel lines including the tank before you install the new bits. Then use the 200cc/tank of 2-stroke FB spec (synth 2 stroke is quite expensive), and drain water from the fuel filter every month or so.
Thumbs Up
Don't think FB spec is good for the Puma. Needs to be FC as I have been told the Puma has a catalytic converter. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #73353 29th May 2011 5:44pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
It is back
Very Happy Got my 130 back from the dealer - they decided to change all 4 injectors, and it runs better than ever. Sure it still sounds like a Ford....
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #73857 2nd Jun 2011 10:23am
dgardel
Italy
Re: It is back
CRJ
Happy for you Thumbs Up
Warranty work or you must pay for it? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #73858 2nd Jun 2011 11:18am
MK
Re: It is back
CRJ
Thumbs Up . Now take care of them. Drain regularly any water from the collector and use (if you want) the 2-stroke "additive". Puma 110" SW
Post #73859 2nd Jun 2011 11:55am
CRJ
I will take care of them - and use 2 stroke. I am not going to have them changed again, it was not warranty work, and all in all with filterchange etc. it was too close to 3.000 eur.
Now the only little problem is, that the injectors need to be "fine" adjusted - they needed an update on their computer to do it - do not know how much it changes the way the engine is running.
Regards
Puma 130 - 08- sold
110 CC 2003
Post #73862 2nd Jun 2011 12:11pm
CRJ
2 Stroke
I know it is a bit off topic, but today I added a dash of 2 stroke when putting gasoline on my old 88´´, wauw what a difference - the engine sounds sooo much better Thumbs Up thanks for the advice - it sure works on petrolengines as well.
Regards
Puma 130 - 08- sold
110 CC 2003
Post #74251 4th Jun 2011 7:08pm
Eric L
France 2007 Defender 110 Puma 2.4 SW Alpine White
Hi,
Same issue on my 2007 110 and 105000km three weeks ago , fixed by 4 news injectrors.
One of them was completely distorted :
Post #295641 4th Jan 2014 10:03am
CRJ
Mine is on 130.000 km now - and a broken engine - hole in one piston probably due to injector not working properly - make sure it is changed in time…
Regards
Puma 130 - 08- sold
110 CC 2003
Post #295702 4th Jan 2014 3:08pm
Eric L
I hope pistons are OK !
The engine has not been opened ...
I start to save money to buy a new engine
Post #295706 4th Jan 2014 3:39pm
CRJ
I do not think you need to worry - my injectors was changed at 45.000 km… now it is on 130.000 km. Think i noticed a faint knocking again for the last 5.000 km - but only when cold - thought nothing of it - until now Big Cry 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #295709 4th Jan 2014 3:51pm
Eric L
Do you change your engine ?
Here a swap with a refurbished engine is 12000 Euros.
If I make 85000 km more , I will be happy.
Less than 18000km/year .
I live near Lourdes , it could be helpfull Mr. Green
Post #295715 4th Jan 2014 4:28pm
CRJ
I haven´t changed it yet. I can get a transit engine for around 2.000 eur - but there is 4 different types of engines - still haven´t figured out which one is the right Confused 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #295720 4th Jan 2014 4:44pm
Eric L
The right type is 244DT
Here is a 2008 Defender engine but 4690 euros: Crying or Very sad
http://www.leboncoin.fr/equipement_auto/590295754.htm
Sold by PRO in Europe.
Here an other rrefurbished :
http://www.ebay.fr/itm/2008-Landrover-Land...1160313505
"244dt motor" in google and make your choice Thumbs Up
Post #295738 4th Jan 2014 5:42pm
CRJ
Update on my engine - ALL 4 pistons cracked - piston on cylinder one has a fine 15 mm. hole right through - no wonder it was smoking like h… Can´t help wondering if my engine was one of them who should have been changed? New injectors at 45.000 due to knocking on startup and now 4 dead pistons at 130.000 ??
New original pistons is about 600 € ex vat. a piece Big Cry in Denmark - anyone know of any supplier that delivers parts one would dare to use - hate to think of changing them again because of poor quality.
Or alternatively the engine code for the transit engine that fits in the defender - seems to be 4 different types.
Best regards
Puma 130 - 08- sold
110 CC 2003
Post #302826 28th Jan 2014 1:36pm
CRJ
Very Happy Very Happy Very Happy New engine fitted - finally!! Found one with 66.000 kms on the clock - car was wrecked. It runs better than my old engine ever did. Now after 1000 km I am just starting to imagine that the engine have developed a knocking sound - gonna try with tinfoil around my head first…..
Question is - how much does pump calibration and injector learning affect the engine? I run with the original ecu - just plugged in new engine and drove off without problems - do I need to have it plugged in and have all the calibration etc. done?. No remap or similar - never again.. Sad
Best regards
Puma 130 - 08- sold
110 CC 2003
Post #323709 14th Apr 2014 5:53pm
