Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 6 of 35 <123 ... 567 ... 333435>
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
1) 2013 (2014MY designation)
2) 2.2
3) Y
4)33630
Due to Gbox oil leak I was able to asses the shaft. It was 'greased' at circa 20K at the local main dealer when they did the engine oil leak under warranty. and TBH It was mainly dry with some powder rust marks and only a small amount of something that looks like silver slip on it. The picture shows it after cleaning up. I have thoroughly re-greased it and reassembled, as the splines look fine.
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #719623 25th Jul 2018 10:46am
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
1. 2010
2, 2.4
3, Y
4, 161,000 miles
Good mix of driving between taking it easy and flooring it with 1/3rd being stop/start/country roads and 2/3rds motorway. Vehicle driven with apr 250-300kg of load most of time plus 10k of mileage towing up to 3000kg. Diff Lock & Low ratio used quite often. 3rd clutch.
I think I have been lucky, so far!!
Post #719636 25th Jul 2018 12:24pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
1. 2010
2. 2.4
3. Yes (original as far as I know)
4. 31,000 miles
Thumbs Up
Post #720862 1st Aug 2018 5:09pm
23GPS
United Kingdom 2007 Defender 110 Puma 2.4 SW Keswick Green
1. Build date July 2007
2. 2.4
3. Y
4. 122k
1. Build date July 2015
2. 2.2
3. Y
4. 24k Keep it simple - poverty spec.
Post #723511 15th Aug 2018 12:01am
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
My sister's 90sw
1, vehicle year of manufacture :2013
2, engine type 2.4 or 2.2 :2.2
3, is the Defender still running with the original output shaft? (Y/N) :N
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running. :22,000
If the shaft has previously failed, please answer 5 & 6.
5, Has an Ashcroft modified part has been fitted? (Y/N) N - standard parts fitted under warranty
6, vehicle milage at the second failure, or milage if still running. No second failure yet, 48,000.
No off roading, not much mechanical sympathy either! Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #723514 15th Aug 2018 1:40am
doublea
My 110UW
1, vehicle year of manufacture 2015
2, engine type 2.4 or 2.2 2.2
3, is the Defender still running with the original output shaft? (Y/N) Y
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running. 33000
No off-roading, much mechanical sympathy, may have been greased when crankshaft oil leak repaired under warranty at c. 10000. Drivetrain clunk currently present, despite, rear half shafts recently replaced under warranty. Current Steeds:
2000 Elise
Post #723515 15th Aug 2018 1:45am
doublea
Mrs doublea's Adventure 90
1, vehicle year of manufacture Nov 2015
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running. 9000
Green goo present at time of delivery. No significant clunking yet. Current Steeds:
2000 Elise
Post #723516 15th Aug 2018 1:48am
Eduardo
1, vehicle year of manufacture: 2007
2, engine type 2.4 or 2.2: 2.4
3, is the Defender still running with the original output shaft? (Y/N): Y
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running: 300.000 km
Cheers and knock wood Eduardo
Post #723640 15th Aug 2018 7:25pm
Bluest
Any view on whether 90s, 110s or 130s are more prone to failure? It feels like I hear about more 110s, but that might just because I pay more attention to those because that’s what I have. 2007 110 TDCi Station Wagon XS
Post #724486 20th Aug 2018 9:50pm
DSC-off
Hi, the survey did not include the question of 90, 110 or 130.
The questions were focused on manufacturing year and milage, to see if there were particularly bad years or a trend.
In my opinion the problem is associated to the gearbox, coupling, shaft and transfer box. The manufacturing tolerances, materials, heat treatment and assembly conditions of those parts.
All of which are common to the 3 wheelbase variants, so I would not expect to see any one being different to the others.
The responses include failures on low milage, lightly used 90's, so load and weight were not a factor in those cases.
When the number of replies reaches a worthwhile number I will update the survey results. Last check showed it was still in line with the charts on page 5 of the thread. Thumbs Up
Post #724503 20th Aug 2018 10:43pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
1, Jan 2015
2, 2.2
3, N
4, 29000
5, Has an Ashcroft modified part has been fitted? Y
6, still running; 29050
BAS 170 Map
Overland Use
Post #724527 21st Aug 2018 10:11am
MK
If have a close look at the output shaft from the gearbox, beside the longitudinal splines there are some very fine ones across as well. Are they designed for lubrication purposes? I'm not an engineer so I may be talking BS Puma 110" SW
Post #724549 21st Aug 2018 12:21pm
MK
If you have a close look at the output shaft from the gearbox, beside the longitudinal splines there are some very fine ones across as well. Are they designed for lubrication purposes? I'm not an engineer so I may be talking BS Puma 110" SW
Post #724552 21st Aug 2018 12:22pm
Fat Cog
1. 2008
2. 2.4
3. Yes
4. Sold with 98000k on the clock & original shaft still working fine & no problems; this vehicle was used off road very frequently & also towed an Ifor Williams horse trailer with two bloody great horses!
1. 2016
2. 2.2
3. Yes
4. 11000k & no problems...yet! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #724603 21st Aug 2018 4:37pm
Do you have a picture? None of the shafts I have seen are like this, and I would suspect that they are machining marks or similar.
There is no factory provision for lubrication on these parts at all, hence the problems.
Post #724606 21st Aug 2018 4:44pm
