![]() | Home > Technical > Insulation tape recommendations |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Personally for me,
It’s got to be soldered, and heat shrink. I also use heatshrink terminals too, which are nice to use. ![]() Wanted, Forward Control Anything considered. Last edited by ian series 1 on 28th Mar 2018 10:03am. Edited 1 time in total |
that man Member Since: 17 Dec 2016 Location: Cheshire Posts: 83 ![]() ![]() ![]() |
H You could use "self amalgamating tape" it bonds to its self to make a waterproof seal. some sparks on hear will tell you better. I remember the sparks offshore using it but get a good quality one like 3M maybe.
Self amalgamating tape works, but personally I cut and splice.
For small joints I use the self soldering heat shrink joints, for larger joints I use heat shrinkable crimps. https://www.beal.org.uk/electrical-product...ge-25.html ![]() https://www.beal.org.uk/electrical-product...r-red.html ![]() |
Self amalging tape makes weather-proof joints, heat-shrink sleeving doesn't.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
You can get self sealing heat shrink which makes waterproof joints. I can't remember what it's called now but my mate had some and it's brilliant stuff
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Is that in a tape form? If it is sounds ideal for making a non cutting splice! 2010 Defender 110 Station Wagon, Santorini Black.
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
I've looked at it on you tube. Looks great
![]() I'll try this one time. First solder it and then this tape. As far as i can judge it, it's works the same as heat shrink sleeves but then with glue (should also be watertight). a defender from 1984 pretending to be a puma with a touch of Range Rover |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17721 ![]() ![]() ![]() |
Adhesive-lined heatshrink will be weatherproof if properly formed.
Is this the one you mean? Looks great however, I checked on various electronics web sites, unfortunately it’s horrendously expensive! 2010 Defender 110 Station Wagon, Santorini Black. |
No this isn’t. When i’am at my laptop i Will search for video i saw a defender from 1984 pretending to be a puma with a touch of Range Rover
That's why I linked to glue lined heatshrink products ![]() |
Why i like this product that you don’t need heat. And sometimes when fixing wires the absence of a flame can be benificial Ahum
Whilst doing some further research came across this :
&time_continue=30 With a smaller brush it may be suitable? 2010 Defender 110 Station Wagon, Santorini Black. |
