Home > Technical > Insulation tape recommendations
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
I intend to install a cruise control soon and I'm looking for recommendations regarding insulating the spliced joints. I think I'm right in thinking that in order to splice into an existing cable and insulate using heat shrink tubing I have to cut the cable completely and slide on the heat shrink before soldering the 3 wires?
The other option is to bare the insulation on the existing cable then wrap the joining cable, solder and insulate with tape?
I think I prefer option 2 so can anyone suggest a quality brand or supplier of insulation tape? Too often in the past Ive used generic insulation tapes which, after a short time have gone all sticky or hard. I have used self amalgamating tape for some jobs but this tends to be awkward to apply in a confined space and makes a rather large joint.
I take it that there is no such thing as a heat shrink tape to wrap joints?
Thanks,
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #696665 28th Mar 2018 8:52am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Personally for me,
It’s got to be soldered, and heat shrink.
I also use heatshrink terminals too, which are nice to use. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #696666 28th Mar 2018 9:01am
that man
England 2012 Defender 90 Puma 2.2 HT Corris Grey
H You could use "self amalgamating tape" it bonds to its self to make a waterproof seal. some sparks on hear will tell you better. I remember the sparks offshore using it but get a good quality one like 3M maybe.
Post #696667 28th Mar 2018 9:03am
Cupboard
Self amalgamating tape works, but personally I cut and splice.
For small joints I use the self soldering heat shrink joints, for larger joints I use heat shrinkable crimps.
https://www.beal.org.uk/electrical-product...ge-25.html
https://www.beal.org.uk/electrical-product...r-red.html
Post #696709 28th Mar 2018 11:47am
Laurie
Self amalging tape makes weather-proof joints, heat-shrink sleeving doesn't.
Post #696711 28th Mar 2018 12:17pm
grafty99
You can get self sealing heat shrink which makes waterproof joints. I can't remember what it's called now but my mate had some and it's brilliant stuff Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #696715 28th Mar 2018 12:37pm
ChrisCM
Is that in a tape form? If it is sounds ideal for making a non cutting splice! 2010 Defender 110 Station Wagon, Santorini Black.
Post #696717 28th Mar 2018 12:44pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I've looked at it on you tube. Looks great Thumbs Up
I'll try this one time. First solder it and then this tape.
As far as i can judge it, it's works the same as heat shrink sleeves but then with glue (should also be watertight). a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #696720 28th Mar 2018 12:55pm
Adhesive-lined heatshrink will be weatherproof if properly formed.
Post #696730 28th Mar 2018 1:59pm
ChrisCM
Is this the one you mean?
Looks great however, I checked on various electronics web sites, unfortunately it’s horrendously expensive! 2010 Defender 110 Station Wagon, Santorini Black.
Post #696744 28th Mar 2018 3:16pm
Tdi4
No this isn’t. When i’am at my laptop i Will search for video i saw a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #696757 28th Mar 2018 4:16pm
Cupboard
That's why I linked to glue lined heatshrink products Smile
Post #696763 28th Mar 2018 4:44pm
Tdi4
Why i like this product that you don’t need heat. And sometimes when fixing wires the absence of a flame can be benificial Ahum Whistle a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #696765 28th Mar 2018 4:48pm
Tdi4
Post #696767 28th Mar 2018 4:50pm
ChrisCM
Whilst doing some further research came across this :
&time_continue=30
With a smaller brush it may be suitable? 2010 Defender 110 Station Wagon, Santorini Black.
Post #696772 28th Mar 2018 5:08pm
