Home > Technical > Insulation tape recommendations |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Personally for me,
It’s got to be soldered, and heat shrink. I also use heatshrink terminals too, which are nice to use. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. Last edited by ian series 1 on 28th Mar 2018 9:03am. Edited 1 time in total |
28th Mar 2018 9:01am |
that man Member Since: 17 Dec 2016 Location: Cheshire Posts: 83 |
H You could use "self amalgamating tape" it bonds to its self to make a waterproof seal. some sparks on hear will tell you better. I remember the sparks offshore using it but get a good quality one like 3M maybe.
28th Mar 2018 9:03am |
Self amalgamating tape works, but personally I cut and splice.
For small joints I use the self soldering heat shrink joints, for larger joints I use heat shrinkable crimps. https://www.beal.org.uk/electrical-product...ge-25.html https://www.beal.org.uk/electrical-product...r-red.html |
28th Mar 2018 11:47am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Self amalging tape makes weather-proof joints, heat-shrink sleeving doesn't.
28th Mar 2018 12:17pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
You can get self sealing heat shrink which makes waterproof joints. I can't remember what it's called now but my mate had some and it's brilliant stuff 2002 90 Td5 Station Wagon
28th Mar 2018 12:37pm |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
Is that in a tape form? If it is sounds ideal for making a non cutting splice! 2010 Defender 110 Station Wagon, Santorini Black.
28th Mar 2018 12:44pm |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
I've looked at it on you tube. Looks great
I'll try this one time. First solder it and then this tape. As far as i can judge it, it's works the same as heat shrink sleeves but then with glue (should also be watertight). a defender from 1984 pretending to be a puma with a touch of Range Rover |
28th Mar 2018 12:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17359 |
Adhesive-lined heatshrink will be weatherproof if properly formed.
28th Mar 2018 1:59pm |
Is this the one you mean? Looks great however, I checked on various electronics web sites, unfortunately it’s horrendously expensive! 2010 Defender 110 Station Wagon, Santorini Black. |
28th Mar 2018 3:16pm |
No this isn’t. When i’am at my laptop i Will search for video i saw a defender from 1984 pretending to be a puma with a touch of Range Rover
28th Mar 2018 4:16pm |
That's why I linked to glue lined heatshrink products |
28th Mar 2018 4:44pm |
Why i like this product that you don’t need heat. And sometimes when fixing wires the absence of a flame can be benificial Ahum a defender from 1984 pretending to be a puma with a touch of Range Rover
28th Mar 2018 4:48pm |
28th Mar 2018 4:50pm |
Whilst doing some further research came across this :
&time_continue=30 With a smaller brush it may be suitable? 2010 Defender 110 Station Wagon, Santorini Black. |
28th Mar 2018 5:08pm |
