![]() | Home > Technical > Insulation tape recommendations |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Also an interesting product i must say
![]() Not per Se for wires, it’s a bit messy. But for insulating ie a connector it looks perfect. a defender from 1984 pretending to be a puma with a touch of Range Rover |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
Most hot air guns come with a heat shield that clips onto the nozzle specifically for heat shrink tubing
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Good luck wrapping amalgamating tape around a single, or even a pair of wires of the type used in 12v vehicle electrics
![]() Fine around rigid or semi-rigid pipes of 10mm or more but small flexible wires - you just can't get the tension required to seal/set. |
Thnx supa.
Haven’t thought of that. ![]() But still interesting thread. I really like to hear other ways to do things. a defender from 1984 pretending to be a puma with a touch of Range Rover |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Yep, I agree entirely, I’ve mainly used it for insulating large co-ax feeders into n type or pl259 plugs, it is pretty rigid and about ½ inch in diameter. So still looking for a recommendation for a decent brand of insulation tape. 2010 Defender 110 Station Wagon, Santorini Black. |
I'd go so far as to say that insulation tape does more harm than good when wrapping vehicle electrics. Fine for sealing some split conduit & using it to help route some single cables but every bit I have ever put on has never kept water out.
I believe the modern heat shrink does a better job. In the back of the garage I have some ex military sticks of sealant. From memory they look and feel like candles & you were meant to melt them into & around the bits to be waterproofed. |
okami Member Since: 06 Apr 2017 Location: Hertfordshire Posts: 90 ![]() ![]() ![]() |
Solder and heatshrink for sure. I've used the all-in-one solder heatshrink splices to great effect as well, but I always put a traditional heatshrink sleeve over them as well.
For bundling/managing wires I use either braided nylon sleeves or tesa tape. The latter obviously only for interior cabling. |
If you really want a recommendation of a tape brand, I have some Sparks branded tape that's decent enough.
I last got some whilst at uni and I left there in 2011. The leftover stock I've got is still going strong. |
