Home > My Defender > An Anorak's Utility Station Wagon
Page 49 of 57 <123 ... 484950 ... 555657>
Co1
Looks good Darren, might be the inspiration I need to sort mine out!
Post #918260 23rd Aug 2021 6:07am
Everybody needs a shiny fuel filter guard Laughing Darren
Post #918267 23rd Aug 2021 7:11am
Dinnu
Re: Fuel Filter Guard Refurbishment
LandRoverAnorak wrote:
I have seen the left type fuel filter covers on Td5s and the right cover on Pumas.
Nice work there. Did you also treat the bracket that bots to the chassis which the filter housing bolts to? As it is typical, the paint on that is only a few microns thick, and of course no metal preparation at all. On a 90 there are the welds for the A frame cross member behind that bracket, and traps moisture behind it and corrode the chassis.
I also found a severe case of galvanic corrosion on one of the bolts that hold the fuel filter housing to the bracket. Below picture of the bolt.. pic taken when the Defender was 7 years old. But perhaps was good, as it sacrificed itself to protect more expensive parts to replace Whistle
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #918270 23rd Aug 2021 7:21am
No, just the cover this time around. Getting at the backing plate is obviously much more involved and I didn't want to disturb it all for what was supposed to be a quick task. I did clean it up and coat the visible bits with Dinitrol before refitting the cover, though. Darren
Post #918273 23rd Aug 2021 8:14am
Dinnu
Yeah a bit more work for the back plate. IIRC I could fix the filter housing directly to the chassis with just one bolt so I could still use the Defender while cleaning the back plate and waiting for the paint to harden. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #918316 23rd Aug 2021 1:23pm
Receiver Hitch - NATO Hitch
Finally had chance to mate my NATO hitch with the vehicle via the receiver and very smart it looks, too.
It's attached via an adapter obtained from Whirly90 of this parish and given a fresh coat of paint:
It obviously comes up lower (about 130mm) than if it was bolted directly to the chassis, but that should work ok for my particular application. Darren
Post #920324 7th Sep 2021 9:04am
L110CDL
It does look good there Darren and with it being red, easier to see Wink Clayton.
Keeper.
Post #920599 8th Sep 2021 9:11pm
Absolutely Laughing My wife and I are collecting a trailer this weekend (albeit with her Discovery) so hope to give it a try out next weekend. Darren
Post #920636 9th Sep 2021 7:08am
Matt110
Looks really good. It's the receiver hitch adaptor possible to buy anywhere? That looks ideal. I was about to buy another drop plate and put it on upside down to get it to the right height but it's so big and cumbersome to have around when not needed or in towing with a ball hitch. Need two of them!
That looks the ideal solution. Never seen one before.
Post #920640 9th Sep 2021 7:37am
Matt110
Ah... May have just answered my own question.
Is it this one?
https://www.4x4overlander.com/product/nato...5gQAvD_BwE
Post #920641 9th Sep 2021 7:40am
Yes, although despite what their website says, they didn't have any in stock a couple of weeks ago and didn't know when they would. They're made by Safari Equip but was told that they have a huge backlog.
They're also available from Extreme4x4 (and they're cheaper, too) but I expect that they're same part and are also out of stock.
http://www.extreme4x4.co.uk/Store/Recovery...o-receiver Darren
Post #920648 9th Sep 2021 8:34am
Matt110
I had an email conversation with extreme 4x4 about a transmission guard once and got the combined total of about 8 words spread across 6 emails, so I gave up in the end. A little effort goes a long way.
I like safari equip kit. The bar is from them and it's robust. Though the coating has failed at 3 years old which seems a bit short for a 100% garaged vehicle.
Post #920728 9th Sep 2021 6:29pm
Had an interesting failure of my Optimill removable boss yesterday. I came to remove the wheel but couldn't pull the right hand toggle. I discovered that the roll pin that secures it had worked loose and unfortunately, when I pushed it back in it was in the wrong place - within the coils of the spring on the toggle.
I had to unbolt the steering wheel complete with boss and then dismantle the whole thing before I could extract the roll pin and put it back where it belonged.
 Darren
Post #922904 26th Sep 2021 8:58pm
Landymatt
I had a roll pin drop out a few times on mine, opened it up enough to stay put after a couple of attempts.
Post #922919 26th Sep 2021 10:20pm
If it comes out again I expect I'll deploy the superglue! Darren
Post #922920 26th Sep 2021 10:21pm
