![]() | Home > My Defender > An Anorak's Utility Station Wagon |
They're either 1100 or 1150kgs - can't remember which. Darren
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10946 ![]() ![]() |
Thanks Darren
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
They look great in that colour
Thanks, Jim
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Mmm. Not a fan of boosts, but each to their own. However I’m rarely a fan of colour-coded wheels, unless it’s black on black. Always prefer a contrast. So LRA, not sure about this upgrade. Black boosts, yup. But Orkney not really doing it for me, Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Heh, heh, this is clearly one of those moments for which the phrase 'each to their own' was invented
![]() To be honest, I've gone right off black wheels. I've done it on two Land Rovers now, including Sawtooths on this one, but these days it seems like every man and his dog has them and they're no longer special. From there, the options for me were limited: silver is too standard and anything else too 'odd' with the metallic grey that is Orkney. I thought I'd give colour coded a try as you don't see it often with alloys. The results prove beyond a shadow of a doubt that you are, of course, completely wrong ![]() ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 23rd Nov 2020 10:17am. Edited 1 time in total |
I think your right about silver looking odd, personally I would have gone black too but I also like the colour coded option
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Ah, silver's ok but just too ordinary; it was other things that I was thinking of as odd. I'm a big fan of white Wolf wheels for example, but they just don't look right on a vehicle with metallic paint, IMHO. Darren
Some time ago, I noticed a series of stone chips on the front of the bulkhead below the windscreen. Initially, I just wiped them over with ACF50 every now and again but I recently noticed the beginnings of rust bubbling through, so decided to get something done about it. I took it to the local ChipsAway guy, who masked it up and resprayed the whole area and I'm very pleased with the result. Of course, it's been raining since, making it difficult to get a decent photo but I'm sure you get the idea:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 2nd May 2021 8:12pm. Edited 1 time in total |
Looks like a job i would be happy with as well Darren
Now that the nights are drawing in again and I find myself using the sidelights more often, I've realised that I'm getting some LED-induced radio interference. To try and resolve it, I've fitted some ferrite rings to the wiring feeding the LED stop / tail lights that I fitted a few months ago:
![]() Click image to enlarge As with the others that I've done previously, these are clip-on units and are very easy to fit. Whilst I had it apart, I also took the opportunity to move the NAS light plinths slightly lower so that they sit wholly within the curve of the bodyside rather than projecting above it. I was able to do this as the LED lights are much shallower than the original incandescent bulb units and don't pass through the hole into the body. All that was required was to drill two new 4mm holes in each plinth, 8mm higher than the originals: ![]() Click image to enlarge I will, of course, keep an eye on the fuel consumption to see what difference this aerodynamic upgrade has made ![]() ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
At least an extra 10mpg I expect
I'd be disappointed at anything less
Tumbiri Member Since: 01 Nov 2016 Location: Caribbean Posts: 52 ![]() ![]() |
Fat Cog, LRA, I read your posts with great interest. My 2013 Puma 2.2 has strange power noises that crop up from time to time; sounds like the turbo is running or the engine revs are hanging. Having said that, I'm not really too sure what a running turbo should sound like (trying to decipher what is what with all the noise is not easy) and when it should kick in, and my RPM seems to hang at 2000 when changing gears (changing up). It was hanging before at 3000rpm but that snag looks like it has gone away after I changed the EGR valve (loss of power) which was flagged by the diagnostics. Maybe it's the same issue! I read on a post that the 2.2 rpm normally hangs to enable smooth gear changing. Not convinced.
My latest issue is with the MAF sensor wiring (I've ordered the MAF connector with wires, thanks LRA!) which results in limp mode, brings on the ENG light, and MAF sensor being flagged on diagnostics. When I fiddle with the wiring, all returns to normal. I'm wondering if the MAF sensor could also be causing the operation that creates the noise. I would have thought that a dodgy turbo actuator would show up a code. Do you know if there is one? Appreciate your comments. Rikhi
