![]() | Home > Puma (Tdci) > Another output shaft..... |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 ![]() ![]() ![]() |
Bit of corrosion here! Inside the dust cover there is a significant quantity of rust and shiny particles. There is discernible movement between shaft and hub, which I expect is causing the clunk on taking up drive. 39 month old, 30k miles 2.2 110. Unlubricated splined shafts eh!
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
Mine went this week too - 2010 with 59k Miles.
Also took the output flange with it making it even more painful! ![]() |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
Yep, Typical LR "High quality finishing and top notch engineering".... Tragically, Someone will get seriously hurt or killed before LR do what they should have done from the start and re-called them for this woeful piece of "engineering".....
Remember, These joins should have grease from the factory (quote LR blurb)... But don't due to cost savings on time and material..... Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
Curious, as the one just replace for third time, was fitted under warranty at 3 years old. The broken shaft looks just like all the photos showing a bone dry rusty connection. So this means JLR dealer replaced it with no grease, despite this being the known issue. Or the grease has completely dried and disappeared over the last 3 years and it broke anyway?
I know it was well greased this time so I guess I'll only find out in 3 years time! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 331 ![]() ![]() ![]() |
The latter Ashcroft kits had a modified seal arrangement to reduce the possibility of leaks - although if it leaks then it proves the joint is being lubricated!
The outer part of the Ashcroft kit virtually locks the adaptor shaft in place so should reduce the potential for wear due to unwanted movement. It would be interesting to see an Ashcroft kit after say 50K miles on a vehicle that previously had suffered shaft failure at low miles. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17640 ![]() ![]() ![]() |
I don't think it makes much difference since since the shaft is still located by the spring ring, although the limit of movement may be smaller if the spring ring fails to locate the shaft.
Absolutely! There must be high-mileage Ashcroft shafts around now and it would be extremely interesting to see one. |
benh78 Member Since: 29 May 2018 Location: UK Posts: 19 ![]() ![]() ![]() |
Would it be possible to raise this as group complaint in the uk via something like watchdog? I’ve not had this issue yet but thanks to forums I know it’s in my future. Turbo hoses blowing off/ splitting seem to have been kind of fixed but at least Land Rover have tried to do things to address although silicone hoses and a bigger better intercooler are prob better fixes then JLR.
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
I did some searching and couldn’t find any examples of long-term usage of the Ashcroft shaft. Dave
Green Goddess - 1998 Defender 110 300tdi |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 560 ![]() ![]() ![]() |
Hi doublea, I'd have a short visit at the retailer. The spigot bore is part of the service schedule. The retailer has to check for corrosion, too.
I also experienced that the retailers leave some points of the service schedule. That's why I service on my own / on demand with retailers and indies. |
Yap. I had an Ashcroft kit fitted and did a three week's research prior to the decision. I did not find anything about a broken Ashcroft kit. Only the Genuine Land Rover "dry splines" / "greased splines" may brake multiple times. I suppose the kit has been shipped from 2014 onwards. We'll have to wait about 2...3 years if we want to know for sure ![]() I'm still wondering why there is no shaft failure on the early Pumas - MY 2007...2010. It seems like everything began in 2011. Ashcroft developed their fix a few years later. The key question is : Why don't the early Pumas fail? |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 93 ![]() ![]() ![]() |
With my cougar 2008 I already have 200 thousand km without touching anything.
Land Rover Genuine Quality ![]() This causes the clunk between moving forwards and backwards: |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1332 ![]() ![]() ![]() |
[quote="Julie"]
I bet the service schedule item referring to spigot bore relates to applying copper slip to the mating area between the alloy wheel and the outer area of the drive flange. Not to the half shaft ends. I suspect most dealers won't even remove the road wheels and they will check for disk/pad wear by looking at the caliper with the wheel in place. ![]() The corrosion check will also be limited to bodywork and chassis. I'll eat my hat if any any corrosion inspection has ever involved removing the drive shaft plastic caps to check for red powder within. Or a check on the output shaft. |
I would also be interested in how to escalate this. Any lawyers on the forum who could provide an insight into the chances of a successful class act or equivalent? Sadly, I fear only significant negative media reports, or worse still, a major accident caused by the output shaft failure, will force JLR into a recall/rework. I may be paranoid, but every time I drive the Defender, I am wondering if the shaft will let go ![]() |
