Home > My Defender > here she is |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
good stuff! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
12th May 2019 3:44pm |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
Another pit run done , the ground was sooooo rock hard , so I let my daughter and others drive it mostly as my bones couldn’t much of that , was brilliant fun none the less , seeing others drive it across the lake and then seeing them smile afterwards was great
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
19th May 2019 2:16pm |
19th May 2019 2:17pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10817 |
Nice pic's 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
20th May 2019 8:44pm |
hello everyone , its been a while , but i`ve got the defender out of the storage hedge and shes now got a week to be got ready for her mot , on the way back from her holiday , her indicators packed up and a knock has been introduced at the back , hmmmmmm , into the garage i go
13th Jul 2019 10:40am |
Only 600 miles this past year , but mainly around a pit , so here’s my failed list , I thing these are the 3rd set of brake pads , but can’t remember
Rear Brake pad(s) less than 1.5 mm thick (1.1.13 (a) (ii)) Front Brake pad(s) less than 1.5 mm thick (1.1.13 (a) (ii)) Repair immediately (major defects): Suspension component mounting prescribed area excessively corroded significantly reducing structural strength Offside and nearside middle chassis in places (5.3.6 (a) (i)) Nearside Front Wheel bearing has excessive play (5.1.3 (a) (i)) Nearside Rear Brake pipe likely to become detached or damaged (1.1.11 (d) (ii)) Nearside Rear Lower Suspension arm mounting has an unsafe modification Arm bolt loose (5.3.3 (c) (i)) Steering linkage ball joint has excessive play Steering box arm joint (2.1.3 (b) (i)) Rear fog lamp not working (4.5.1 (a) (ii)) Repair as soon as possible (minor defects): Steering box leaking oil (2.1.1 (e) (i)) Offside Rear Brake pipe inadequately clipped or supported (1.1.11 (d) (i)) Monitor and repair if necessary (advisories): Nearside Front Brake pipe corroded, covered in grease or other material Cross (1.1.11 (c)) |
22nd Jul 2019 2:30pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Oops, quite a list, but hopefully nothing too major. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
22nd Jul 2019 3:28pm |
The garage are not gonna weld it , recommending a new chassis , so will declare it sorn , and either scrap it or sell it with the failed mot ,
22nd Jul 2019 4:09pm |
Oh no, I missed that bit, sorry to hear! Not tempted to galv chassis it? James
22nd Jul 2019 4:26pm |
No money for a chassis , I will now replace the brake pads , sort out the brake pipes , get the fog light working , locate all of the spoken corrosion and remove and weld it all up , put a new wheel bearing in , replace the steering ball joint , I will then put it back in for mot and once sorted , i’ll sort out the steering box . Might take a while , but surely it’s worth it
22nd Jul 2019 5:54pm |
Yes it will be 100% worth it 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
22nd Jul 2019 8:31pm |
Yep , I think you’re right fella , wheel bearing , brake pads , drop link ball joint and a few small sundries came to 110 quid delivered , i’ve got plenty of 3mm sheet steel , this corrosion they say is bothering me , i’ve spent millions of hours removing and welding , how could I of missed such a large amount ? Will report back tomorrow once i’ve collected her
22nd Jul 2019 8:37pm |
Well she’s home , looked at her underneath on a ramp , yes I could do with a new chassis , but that’s not an option , the corrosion is mainly battle damage from the pit , so gotta huge pile of 3mm sheet off cuts coming , and a welding I shall go , but when it’s cooler , it’s a billion degrees in the garage today
23rd Jul 2019 12:03pm |
Nice one razz that your keeping and fixing her up and all that welding to do 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
23rd Jul 2019 8:27pm |
