Home > My Defender > here she is
Page 15 of 26 <123 ... 141516 ... 242526>
razz
2001 Defender 90 Td5 PU Caledonian Blue
Hello everyone , it’s at last a pit weekend coming up , parked her up after last time and not touched , popped to the garage and she fires up instantly Thumbs Up oh I love the new starter , we’ve had a lot of rain this past week , so fingers crossed we got more mud this Sunday Thumbs Up
Post #772787 12th May 2019 3:32pm
Procta
good stuff! Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #772789 12th May 2019 3:44pm
razz
Another pit run done , the ground was sooooo rock hard , so I let my daughter and others drive it mostly as my bones couldn’t much of that , was brilliant fun none the less , seeing others drive it across the lake and then seeing them smile afterwards was great
Post #773878 19th May 2019 2:16pm
razz
Post #773879 19th May 2019 2:17pm
L110CDL
Nice pic's Thumbs Up Clayton.
Keeper.
Post #774114 20th May 2019 8:44pm
razz
hello everyone , its been a while , but i`ve got the defender out of the storage hedge and shes now got a week to be got ready for her mot , on the way back from her holiday , her indicators packed up and a knock has been introduced at the back , hmmmmmm , into the garage i go Thumbs Up
Post #781333 13th Jul 2019 10:40am
razz
Only 600 miles this past year , but mainly around a pit , so here’s my failed list , I thing these are the 3rd set of brake pads , but can’t remember
Rear Brake pad(s) less than 1.5 mm thick (1.1.13 (a) (ii))
Front Brake pad(s) less than 1.5 mm thick (1.1.13 (a) (ii))
Repair immediately (major defects):
Suspension component mounting prescribed area excessively corroded significantly reducing structural strength Offside and nearside middle chassis in places (5.3.6 (a) (i))
Nearside Front Wheel bearing has excessive play (5.1.3 (a) (i))
Nearside Rear Brake pipe likely to become detached or damaged (1.1.11 (d) (ii))
Nearside Rear Lower Suspension arm mounting has an unsafe modification Arm bolt loose (5.3.3 (c) (i))
Steering linkage ball joint has excessive play Steering box arm joint (2.1.3 (b) (i))
Rear fog lamp not working (4.5.1 (a) (ii))
Repair as soon as possible (minor defects):
Steering box leaking oil (2.1.1 (e) (i))
Offside Rear Brake pipe inadequately clipped or supported (1.1.11 (d) (i))
Monitor and repair if necessary (advisories):
Nearside Front Brake pipe corroded, covered in grease or other material Cross (1.1.11 (c))
Post #782567 22nd Jul 2019 2:30pm
JOW240725
Oops, quite a list, but hopefully nothing too major. Thumbs Up James
Instagram @suffolk_rovers
Post #782581 22nd Jul 2019 3:28pm
razz
The garage are not gonna weld it , recommending a new chassis , so will declare it sorn , and either scrap it or sell it with the failed mot , Censored
Post #782583 22nd Jul 2019 4:09pm
JOW240725
Oh no, I missed that bit, sorry to hear! Not tempted to galv chassis it? James
Post #782585 22nd Jul 2019 4:26pm
razz
No money for a chassis , I will now replace the brake pads , sort out the brake pipes , get the fog light working , locate all of the spoken corrosion and remove and weld it all up , put a new wheel bearing in , replace the steering ball joint , I will then put it back in for mot and once sorted , i’ll sort out the steering box . Might take a while , but surely it’s worth it
Post #782602 22nd Jul 2019 5:54pm
L110CDL
Yes it will be 100% worth it Very Happy Clayton.
Keeper.
Post #782647 22nd Jul 2019 8:31pm
razz
Yep , I think you’re right fella , wheel bearing , brake pads , drop link ball joint and a few small sundries came to 110 quid delivered , i’ve got plenty of 3mm sheet steel , this corrosion they say is bothering me , i’ve spent millions of hours removing and welding , how could I of missed such a large amount ? Will report back tomorrow once i’ve collected her Thumbs Up
Post #782651 22nd Jul 2019 8:37pm
razz
Well she’s home , looked at her underneath on a ramp , yes I could do with a new chassis , but that’s not an option , the corrosion is mainly battle damage from the pit , so gotta huge pile of 3mm sheet off cuts coming , and a welding I shall go , but when it’s cooler , it’s a billion degrees in the garage today
Post #782714 23rd Jul 2019 12:03pm
L110CDL
Nice one razz that your keeping and fixing her up and all that welding to do Bow down Clayton.
Keeper.
Post #782770 23rd Jul 2019 8:27pm
