![]() | Home > My Defender > here she is |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10969 ![]() ![]() |
Nice top pic
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5274 ![]() ![]() |
looks good pal, and you have a good one too
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
Cheers dudes , pulled the wiring harness out of the chassis for a spot of re-routing , slowly removing the dashboard , the towels catch the draft , not sure what to do next , weld the chassis, weld the bulkhead , replace the front window with a series split screen , fit a flat roof , change the doors , gonna go for a removable rear n a removable front , just like I used to do with me mini’s , the list is endless
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
No need to fit a clutch servo just do the clutch pedal spring mod, it halved the effort required on mine and cost about £15. Plenty of posts on here about it. 2005 Td5 90 XS
Steve |
Cor , thanks Lou , a quick read and a visit see’s a kit ordered from the bay , it’s another job , but a worth while one if it will assist my daughter . Thank you
HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 752 ![]() ![]() ![]() |
Copy link please 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
It does not look like I have done much , but I sure have . Moved the fuses up cos my daughter likes deep water , can’t move the throttle pedal or crank sensor though
Have removed to one side the heater etc , gonna get cracking on the bulkhead welding before the next pit visit
![]() Click image to enlarge Tail gate nearly done |
razz id change the wiper park switch, while you have the access, even if its ok.
Procta
Where is the park switch please, are these prone to fail? Ta ![]() 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 517 ![]() ![]() ![]() |
Park switch is the white plastic bit that has a black X on drawn on it in razz's photo with wires going into it on the wiper motor. To be honest I wouldn't bother replacing it unless it does die, it's still very easy to get to even with the dash back in, just need to whip the corner piece off. Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
