Home > In Car Electronics > A question for the connector gurus.....
Page 2 of 2 <12
Martin
Site Admin
Looks wider than 2.8mm tabs  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666657 24th Nov 2017 12:54pm
Definitely wider than 2.8mm, it is not a Superseal.
I think that the pump is an AC Delco design, and the connector is (I think) an AC Delco or Standard design, the GM part looks very similar - indeed the pump used on GM vehicles looks the same.
it is entirely possible that Ford used AC Delco pumps and hence the same connector.
I will provide measurements later in the day.
Post #666658 24th Nov 2017 1:12pm
Martin wrote:
The dimension in the picture above is 32.5mm, the outside width on the minor axis is 17.3mm, and the tabs are 6.3mm.
You will have noticed the registration or key lug on the outside in the 10 o'clock position, I am sure.
Thank you for your help. Thumbs Up
Post #666705 24th Nov 2017 5:34pm
Martin
Site Admin
Found it, sent you a PM Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666772 24th Nov 2017 10:48pm
Fantastic, many thanks! Thumbs Up
For the benefit of anyone looking fof this connector in the future, it's an Econoseal 250 Series connector.
What a great forum this is!
Post #666791 25th Nov 2017 9:20am
Screbble
Thanks for revealing Blackwolf as I've been watching and was very intrigued!
Another mystery solved, and no doubt hours and money saved, due to this great forum Thumbs Up
Post #666839 25th Nov 2017 4:55pm
Did it tend to have a specific colour at all? KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #666840 25th Nov 2017 4:57pm
zsd-puma
Martin wrote:
Doubt if it's Ford as the use of the connector pre-dates their ownership of LR.
You'd be surprised. My Rover Mini has VW bits and GM bits on it. The headlamp leveling plugs for example (also used on the Defender), look at the rubber boots, they have VW, Audi logos on them. The coil pack is straight from a Citroen Saxo and the charcoal canister and fuel pump are from a Corsa, complete with GM branding. It seems Rover raided everyone's parts bins, not just their own.
Post #666860 25th Nov 2017 5:40pm
PaulMc
Sorry, I've only just seen this.
Yes, it's an Econoseal 250 series connector, same as used on late D1, and D2 heated windscreens.
Simtek sell them - but only with terminals and seals for 0.5-1.0mm² cable -
https://www.simtekuk.co.uk/product.php/250...:::1593614
I've got them with terminals and seals for up to 3.0mm² cable Thumbs Up Paul.
Post #667072 26th Nov 2017 6:16pm
+1.... my old 200Ti defender (original factory) had a Ford glowplug timer socket (and timer I think)
Post #667388 27th Nov 2017 8:55pm
Martin
Site Admin
Fair enough Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #667419 27th Nov 2017 10:36pm
nitram17
if you want to go the generic route!
https://www.carbuilder.com/uk/search?q=washer+pump
Post #983600 24th Feb 2023 11:38pm
Page 2 of 2 <12
