Home > In Car Electronics > A question for the connector gurus..... |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Looks wider than 2.8mm tabs 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Nov 2017 12:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
The dimension in the picture above is 32.5mm, the outside width on the minor axis is 17.3mm, and the tabs are 6.3mm. You will have noticed the registration or key lug on the outside in the 10 o'clock position, I am sure. Thank you for your help. |
24th Nov 2017 5:34pm |
Found it, sent you a PM 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Nov 2017 10:48pm |
Fantastic, many thanks!
For the benefit of anyone looking fof this connector in the future, it's an Econoseal 250 Series connector. What a great forum this is! |
25th Nov 2017 9:20am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2102 |
Thanks for revealing Blackwolf as I've been watching and was very intrigued!
Another mystery solved, and no doubt hours and money saved, due to this great forum |
25th Nov 2017 4:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20364 |
Did it tend to have a specific colour at all? $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
25th Nov 2017 4:57pm |
You'd be surprised. My Rover Mini has VW bits and GM bits on it. The headlamp leveling plugs for example (also used on the Defender), look at the rubber boots, they have VW, Audi logos on them. The coil pack is straight from a Citroen Saxo and the charcoal canister and fuel pump are from a Corsa, complete with GM branding. It seems Rover raided everyone's parts bins, not just their own. |
25th Nov 2017 5:40pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 501 |
Sorry, I've only just seen this. Yes, it's an Econoseal 250 series connector, same as used on late D1, and D2 heated windscreens. Simtek sell them - but only with terminals and seals for 0.5-1.0mm² cable - https://www.simtekuk.co.uk/product.php/250...:::1593614 I've got them with terminals and seals for up to 3.0mm² cable Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
26th Nov 2017 6:16pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
+1.... my old 200Ti defender (original factory) had a Ford glowplug timer socket (and timer I think) |
27th Nov 2017 8:55pm |
Fair enough 1988 90 Td5 NAS soft top
2015 D90 XS SW |
27th Nov 2017 10:36pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
if you want to go the generic route!
https://www.carbuilder.com/uk/search?q=washer+pump |
24th Feb 2023 11:38pm |
