![]() | Home > In Car Electronics > A question for the connector gurus..... |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
Looks wider than 2.8mm tabs
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17712 ![]() ![]() ![]() |
The dimension in the picture above is 32.5mm, the outside width on the minor axis is 17.3mm, and the tabs are 6.3mm. You will have noticed the registration or key lug on the outside in the 10 o'clock position, I am sure. Thank you for your help. ![]() |
Found it, sent you a PM
Fantastic, many thanks!
![]() For the benefit of anyone looking fof this connector in the future, it's an Econoseal 250 Series connector. What a great forum this is! |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2167 ![]() ![]() ![]() |
Thanks for revealing Blackwolf as I've been watching and was very intrigued!
Another mystery solved, and no doubt hours and money saved, due to this great forum ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20734 ![]() ![]() |
Did it tend to have a specific colour at all? WeWillWin🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
You'd be surprised. My Rover Mini has VW bits and GM bits on it. The headlamp leveling plugs for example (also used on the Defender), look at the rubber boots, they have VW, Audi logos on them. The coil pack is straight from a Citroen Saxo and the charcoal canister and fuel pump are from a Corsa, complete with GM branding. It seems Rover raided everyone's parts bins, not just their own. |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
Sorry, I've only just seen this. Yes, it's an Econoseal 250 series connector, same as used on late D1, and D2 heated windscreens. Simtek sell them - but only with terminals and seals for 0.5-1.0mm² cable - https://www.simtekuk.co.uk/product.php/250...:::1593614 ![]() I've got them with terminals and seals for up to 3.0mm² cable ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
+1.... my old 200Ti defender (original factory) had a Ford glowplug timer socket (and timer I think) |
Fair enough
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
if you want to go the generic route!
https://www.carbuilder.com/uk/search?q=washer+pump |
